Hello, I've just today installed my 2441TH and loaded the plug-in 3.0.6.3. I am using Mark Sandler's Insteon, 3.0.6.36, under HS3 Standard 3.0.0.435.
I believe I've hooked everything up correctly, the thermostat shows up in the HS3 Device page, and I am able to address it and control it from both HS3 and HSTouch. The only problem is, it does NOT show up in the Insteon plug-in Device List. A message appears on the Main Configuration page,
"Externally registered device: Thermostat 1 (Insteon Address 34.52.DE) registered through external plugin"
...but 34.52.DE is nowhere to be found in the Insteon device list. Is this by design or something? Cuz, that's gonna be a problem. I want to be able to link the thermostat to a duct fan, turning it on and off. I don't want to have to use the hardware method, because the duct fan is in an attic - and so is it's ApplianceLinc. The attic is only accessible thru a plain scuttle, no ladder. Just too much of a hassle.
So I'd like to know if there is another method of linking the thermostat as controller to an ApplianceLinc as responder.
