HI,
The 2441TH thermostat has stopped responding to temperature commands from HS3. When I change the temperature, the new setting will show in HS3 display manager, but there is no change at the unit itself. the partial log below shows a command to lower the temp from 78 to 72. the next poll shows the cool setpoint still at 78, which matches what is shown on the display.
I have tried restarting the PI, then I reset the stat to factory default, then tried resetting the PI again, but neither helped.
Sep-04 1:00:27 PM Insteon Thermostat Home Cool SetPoint = 78
Sep-04 1:00:26 PM Insteon Thermostat Home Temp = 74
Sep-04 1:00:23 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6A] [20]
Sep-04 1:00:21 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6B] [03]
Sep-04 1:00:19 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6A] [60]
Sep-04 1:00:17 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6B] [02]
Sep-04 1:00:17 PM Insteon Thermostat POLL thermostat: Home
Sep-04 1:00:17 PM Event Event Trigger "Heartbeat Detection Thermostat poll"
Sep-04 12:58:28 PM Insteon Thermostat Post-startup timer: All thermostats have DEVCAT. Timer exiting.
Sep-04 12:57:52 PM Insteon Thermostat TransmitInsteon: [Home] [1F] [6C] [90] ((([00] [00] [00] [00] [00] [00] [00] [00] [00] [00] [00] [00] [00] [04])))
Sep-04 12:57:52 PM Insteon Thermostat SetCoolSetpoint: Home Cool SetPoint = 72
Sep-04 12:57:52 PM Insteon Thermostat SetCoolSetpoint: Home set cool setpoint to 72 Current cool setpoint = 78 Current heat setpoint = 65
Sep-04 12:56:27 PM Insteon Thermostat Home Cool SetPoint = 78
Sep-04 12:56:26 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6A] [20]
Sep-04 12:56:25 PM Insteon Thermostat ACK of ALL-Link Cleanup Message [60] cmd1 [03] cmd2 [03] -- 01 30 91 7F 33 E2 39 6B 03 03
Sep-04 12:56:24 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6B] [03]
Sep-04 12:56:22 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6A] [60]
Sep-04 12:56:20 PM Insteon Thermostat TransmitInsteon: [Home] [0F] [6B] [02]
Sep-04 12:56:20 PM Insteon Thermostat POLL thermostat: Home
