1. I'm installing a 2441TH in an older house with a simple furnace. Just two wires to the old thermostat. Contact closure turns on the furnace. After adding 24VAC power to 2441TH (I assume that this is necessary) it seems to invert the W1 signal to the furnace. I couldn't find a way to work around this (other than adding an inverter circuit). Am I missing something?
2. Does the HS3 Insteon Thermostat Plugin autoset the clock display on the thermostat...or is this another clock I need to manually set twice a year?
