Using the 2732-242 thermostat with a heat pump.
Q1) Is there a way to get an indication that the secondary (emergency) heat has been activated? Currently it only indicates Heat, regardless of whether its heat pump or emergency.
Q2) Is there a way to control the secondary (emergency) heat?
I find that the thermostat's 5 degree difference before it turns on the secondary heat is too uncomfortable and would like to write some events to control it more closely.
