This event to raise the temperature in the morning always errors:
this is the event:
I have 4 other similar events that run daily with no problems, one more that raises the temperature, three others that lower the temp.
I tried deleting the PI, restarting HS3, then re-installing the PI, but that did not help.
Nov-19 7:00:00 AM | Insteon Thermostat Error | HandleAction - Error executing action: Conversion from string "" to type 'Short' is not valid. |
Nov-19 7:00:00 AM | Event | Event Trigger "Thermostat Heating - Wakeup" |
Event Name: | Type | Group Reassign: | |||||||||||||||||
(Enter New Type Name) | (Create A New Group)Alarm RoutinesAlarm TriggersAway Lighting - Someone HomeAway Lighting - SummerAway Lighting - WinterBlue Iris ControlDefaultDelayed ActionsHeartbeat DetectionLawn PoolLeak DetectionLightingLow Battery NotificationsPower FailSystemTest EventsThermostat | ||||||||||||||||||
Voice Command: |
IF | The time is at 7:00:00 AM |
AND IF | The days of the week are: Weekend days, Tuesday, Wednesday, Thursday, Friday |
Then | Insteon Thermostat : Downstairs Home set heat setpoint to 70 |
