Setting External Sensor Value from Homeseer
  • pmendiuk
    Never mind the Insteon thermostat is a huge step backwards as an actual thermostat. It seems like it has a very primitive control algorithm and no deadband adjustment . My 20 year old Honeywell is much more civilized with the set point than the Insteon.
  • pmendiuk
    I should have been more specific. I would like to generate 2441zth wireless thermostat Insteon messages with a script so that I can transmit and display my weather station outside temperature on the thermostat via the Insteon protocol. The weather station data is already transmitted to Homeseer via MQTT.
  • nfrobertson
    The external sensor is a device wired to a supported thermostat like the 2441zth (Insteon wireless thermostat). It's not something you can set but rather a value you read from that hardware. Perhaps you are looking for something different that would feed your weather station temp info into HomeSeer? I'm sorry I don't have a recommendation for that but assume if you search the boards you can probably find something that will work?
    Nathan
  • pmendiuk
    started a topic Setting External Sensor Value from Homeseer
    I am considering using the Insteon Thermostat plugin with Homeseer and wondered if I can set the external sensor value on the thermostat with a script? I would like to use my weather station temperature data.
