Hello Nathan,
I have been waiting for over a month to hear back on the issues I have been posting. I paid for your plugin but it does not work properly. I don't want my money back but I would like to get a reasonable response on whether you have given up supporting this plugin.
I am pretty sure that you have not tested your plugin with Insteon version 7.36 update. But even with released vsion of 7.1 there are issues. The error of unknow key is due to your pluging getting out of sink with Insteon plugin, through which you commination with the hub. See this thread.
https://forums.homeseer.com/forum/li...79#post1456379
Also, your polling does not work. The current temp value is continuesly incorrect. Using the same Insteon HUB on same network, I get two different values from your plugin and from Insteon HUB APP (which shows correct values). This continues for at least 10 minutes until I hit your "POLL" Button. I can see in the log that you are getting incorrect current temp values so, there again is some type of communication issue between your plugin and Insteon plugin.
Thus, a paid plugin that has to be manually restarted and continuesly polled to get the actual, accurate temperature is not worth the amount I paid.
I am very disappointed.
Felix
Felix
