I have one 2441 adapter, don't know the Device ID, and I feel like I'd probably break it if I tried removing it from the Venstar (if the Device ID is even showing on the side of the adapter against the wall).
Does the Thermostat plugin have anything like the MNS plugin tap-add option, or does it have to be added by Device ID? I didn't see anything but thought I'd ask.
Another thought is I could randomly try all of the links that come up in the MNS plugin Display Interface Links list that aren't already matched to a device - do you know if the 2441 adapter might have specific characters to indicate that particular device (the way Mark has told us that if the first four characters are E2 00 then that indicates the next six characters should be the Device ID of a device previously linked in the system)?
And to add the 2441V, does it need to be put into linking mode to get it added to the plugin? I didn't with the Insteon Thermostats, they were found by the plugin using the device ID, but didn't know if adding a 2441V might be different.
