Thermostat Set point weirdnesses...
This topic is closed.
This is a sticky topic.
    Hey everyone,
    Be aware that the thermostats only send back (and only respond to) messages concerning the set point of the CURRENT mode. In other words, if your thermostat is in "Heat" mode and you change the cooling set point, it will NOT be reflected on the thermostat (because only setpoint messages for the current mode -- which is Heat in this example -- are accepted. Until you change the mode to Cool, the cooling set point will not be accepted (even though the plugin is sending the message). This can cause you to think the thermostat is not responding and is out of sync (and you'd be right) -- but in this case, there is some rationale behind the behavior.
    John
