It's appearing that changes made on the thermostat aren't always (or at all, still testing various permutations) reflected automatically in the Devices HS4 web interface, the HS mobile app, or HSBuddy (which I'm also checking out). When I try Polling and/or Refreshing then that seems to get what's on the thermostat showing in HomeSeer, but curious if Polling and Refreshing serve the same purpose, or is one preferable for getting HS updated with the most recent info from the thermostat?
Polling vs. Refresh
I'm not clear on what you mean by "Refreshing" -- there IS a "Polling" button on the thermostat's HS4 group which sends "request-for-status" messages to the MNS Insteon plugin. There is also the auto-refresh setting on the Insteon Thermostat config page that does the same thing every X seconds -- is this what you mean?
By the way, the thermostat only responds to a "what's the set point" and "set the set point" messages with the set point for the current mode; it is easy to get these out of sync when testing (for example, if, at the physical device, you switch the mode to heat and set the setpoint to 60, then switch to cool and set it to 80 -- and leave the thermostat set to cool, the HS4 Devices page will show the mode as Cool and the cooling set point as 80 -- the heating setup will not update -- until you switch the mode to Heat).
In any case, you should be getting an automatic poll every X seconds based on the auto-refresh setting on the config page; if not, please let me know. thx!
I do see the Auto-Refresh field (defaulted to be set to 20 seconds) in the Control Page part of the General tab of the thermostat plugin Config page.
The "Refreshing" functions I was referring to appear to only be available in the mobile apps (I've actually wondered if there was something similar to that in the web interface for any devices - thermostat or otherwise).
In the HS mobile app it's the circular arrow icon in the upper right that when clicked brings up the Refresh Now box
In the HSBuddy mobile app it's done by pulling down in the middle of the screen.
Of course both mobile apps show the Polling button, but since Refresh is an option as well I was curious if they perform essentially the same function.
Hi John, apologies for my ignorance. This is the first time I am in any forums and am not technically proficient in these matters! Insteon (and iHome) forced me to try and recover from all my time invested over the years. I do understand the setpoint readings are accurate. The "refresh" button does not work on my iPhone...perhaps because this is all still a trial version ? I have the refresh rate set for 5 seconds. on my desktop, but still need to "Poll" manually for the room temperature actual readings to be accurate (within 1 degree). How do I know when the AC is actually cooling when outside the home ? Why am I getting "Plugin reports Device not found" responses for both thermostats ?
So I'm learning that patience is a virtue.....clicking Polling in the Thermostat device in the HS4 web interface will provide an update to the Mode, Temperature, Humidity, and the Heating and/or Cooling numbers (which you've made clear will depend on how the Mode is set at the time).....but it might take several seconds for each of those updates to complete and be displayed.
Is there a way though to have all of this auto-update periodically? Or is it necessary to click Polling after there's been a change in order to have the latest settings and numbers display in the device in HS4 (or the mobile app)?. In the plugin Settings screen General tab under Control Page I have Auto-Refresh set for 20 seconds, but I'm not sure what is auto-refreshed by this setting?
I'm guessing that having multiple thermostats continuously sending updates to HS4 and the plugin would probably generate an awful lot of background data traffic, so that might be why we need to get updated info by polling manually rather than having it continuously refreshing?
Still need to "Poll" manually for the room temperature actual readings to be accurate (within 1 degree). How do I know when the AC is actually cooling on the Devices window ? Why am I getting "Plugin reports Device not found" responses for both thermostats ?
I am nevertheless DELIGHTED to be able to control my 30+ Insteon devices after Insteon abandoned all of it users !!
LBB55, did you get this working? If not, do the following
1) update to latest beta version of the plugin: disable current plugin, add plugin 3.0.8.5, re-enable plugin
2) go to plugin Config page
a) On the General tab, check all the "Log..." checkboxes -- DO NOT forget to Save
b) On the thermostat tab, find your thermostat and click "Update Links" on the right. Wait until the message near the top of the page clears before continuing
3) test -- go to the HS Devices page and note the cool or heat setpoint (whichever mode your thermostat is in), go to the thermostat and change the setpoint, return to HS Devices and verify the setpoint is changed.
IF the test works in Windows-based HomeSeer, you can then try it on the mobile app -- it should work there also. NOTE: I'm still working on Alexa control
If the test does not work, export your log file (HomeSeer -> Tools -> Logs) and post it here.
good luck!
