Name: Insteon Thermostat for HS3
Type: VB.NET 4.0
Requires:
Online help. Or download as zip file.
General Description
Readme and Revision History
HSTouch Notes
HSTouch - you can use the built in Default skin and one of the existing Thermostat templates. Or you can look in HS3\Updates3\Insteon Thermostat3*\InsteonThermostatHSTouch.zip and unzip that into your HSTouch Skins directory which will add a new Thermostat template Insteon. NOTE: I'm seeing an issue with the latest HSTouch designer 3.0.8 and HSTouch Server 3.0.0.22 (and HS3 3.0.0.68) where the TEMP only shows as 0. I've opened an inquiry with the HSTouch forum here.
EXAMPLE: (unzip source to dest)
Source: C:\Program Files (x86)\HomeSeer HS3\Updates3\Insteon Thermostat3*\InsteonThermostatHSTouch.zip
Dest: C:\Users\ENDUSER\Documents\HSTouch\Skins (replace ENDUSER with your login)
Initial Release Notes
I want to thank Tom Christian (Sage for HS2) and Mark Sandler (Insteon plugin) for all their invaluable help! Bravo
If you've used Tom's Sage for HS2 you'll recognize much of the functionality.
Script API is functional. Look in the scripts directory for the example InsteonThermostat_script_api.vb
HS3 devices are required. The persistent state of the plugin is handled mostly by those devices. Only the minimum necessary configuration information is saved to the INI file.
If you enable debug logging, more information will be sent to the HS3 log and additionally to HS3/Logs/InsteonThermostatDebug.log
This plugin has been developed using:
Smarthome 2441TH (wired devcat 050B firmware D)
Smarthome 2441ZTH (wireless devcat 050A firmware D)
Venstar T1800 and 2441V Insteon adaptor (devcat 0503 firmware 95)
Venstar T1700 with integrated Insteon adaptor (devcat 050E firmware 93)
HS3 3.0.0.96
Type: VB.NET 4.0
Requires:
- HS3 3.0.0.258 (or newer)
- Mark Sandler's HS3 Insteon plugin 3.0.5.20 or newer (will not work with HST Insteon basic plugin)
- NOTE! Do not add the thermostat as a device to Mark's plugin. This Insteon Thermostat plugin will register it for you
- Windows HS3 is the primary platform
- Linux HS3 is working but since HS3 is beta on Linux and lots of testing is still needed this is offered for those wanting to beta test. A working Linux HS3 3.0.0.181 and Mark Sandler's Insteon plugin are a pre-requisite.
- Insteon Thermostat or Thermostat with compatible Insteon adaptor
- Smarthome 2441TH (wired)
- Smarthome 2441ZTH (wireless)
- Venstar T1800 and Smarthome 2441V Insteon adaptor
- Venstar T1700 with integrated Insteon adaptor (discontinued but you can find on ebay or refurb at Smarthome.com)
- .Net Framework 4
General Description
HSTouch Notes
HS3 3.0.0.96
