VER 3.0.0.2
VER 3.0.0.68 HS3
The Upstairs Heat set point, and the Upstairs Cool set point as seen here from a cut out of my home page (first picture)
Both Set Point values step up and both Set Point values step down when I run the event below(second picture). The home screen updates, and the values change correctly.
The problem is that the thermostat doesn't actually move it's set points up or down, as you would expect, as view from the wall display unit (WDU).
Is there something I am doing wrong?
VER 3.0.0.68 HS3
