Hi,
I'm getting the error "WARNING: Not connected to Insteon plugin!" displayed in the Plugins / Manage screen.
I have HSInsteon 1.0.6 installed and enabled and Insteon Thermostat 3.0.07 installed, licensed, and enabled. I'm using HS3 Pro Edition 3.0.0.68 (Windows) on a HomeTroller S4 Pro. I shut down HS3, restarted the HomeTroller, started HS3 with no errors. There were warnings for the thermostat plugin.
Here's my startup log:
5/11/2014 12:02:36 AM ~!~Startup~!~Settings Loaded.
5/11/2014 12:02:36 AM ~!~Startup~!~Current sunrise/sunset values calculated.
5/11/2014 12:02:36 AM ~!~Startup~!~*********************************************** *********************************
5/11/2014 12:02:36 AM ~!~Startup~!~ HomeSeer version 3.0.0.68 Edition: HS3 Pro Starting Now
5/11/2014 12:02:36 AM ~!~Startup~!~Using system's regional settings
5/11/2014 12:02:37 AM ~!~Startup~!~Creating Class Objects...
5/11/2014 12:02:37 AM ~!~Startup~!~COM port classes started.
5/11/2014 12:02:37 AM ~!~Startup~!~Application interface class started.
5/11/2014 12:02:37 AM ~!~Startup~!~Web server class started.
5/11/2014 12:02:37 AM ~!~Startup~!~E-Mail SEND class started.
5/11/2014 12:02:37 AM ~!~Startup~!~E-Mail RECEIVE class started.
5/11/2014 12:02:37 AM ~!~Startup~!~Plug-In Interface class started.
5/11/2014 12:02:37 AM ~!~Startup~!~HSPhone external interface class started.
5/11/2014 12:02:37 AM ~!~Startup~!~Local voice recognition class started.
5/11/2014 12:02:37 AM ~!~Startup~!~Database SAVE process started.
5/11/2014 12:02:37 AM ~!~Startup~!~Loading configuration file ...
5/11/2014 12:02:37 AM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files\HomeSeer HS3\Data\HomeSeerData.hsd
5/11/2014 12:02:37 AM ~!~Database~!~Loading Devices...
5/11/2014 12:02:37 AM ~!~Load Config~!~11 total devices loaded.
5/11/2014 12:02:37 AM ~!~Load Config~!~Loading Event Groups...
5/11/2014 12:02:37 AM ~!~Load Config~!~Loading Events...
5/11/2014 12:02:37 AM ~!~Load Config~!~0 total events loaded.
5/11/2014 12:02:37 AM ~!~Load Config~!~Loading COUNTERS...
5/11/2014 12:02:37 AM ~!~Load Config~!~Loading TIMERS...
5/11/2014 12:02:37 AM ~!~Startup~!~HomeSeer version is: 3.0.0.68
5/11/2014 12:02:37 AM ~!~Startup~!~Creating Speaker Client Interface Object...
5/11/2014 12:02:37 AM ~!~Startup~!~This version of HomeSeer is registered as a HS3PRO version.
5/11/2014 12:02:37 AM ~!~Info~!~Remote plug-in API interface started on port 10400
5/11/2014 12:02:37 AM ~!~Startup~!~Checking for available plug-ins
5/11/2014 12:02:38 AM ~!~Plug-In~!~Found plug-in: ADIO-100, version: 3.0.0.20
5/11/2014 12:02:38 AM ~!~Plug-In~!~Found plug-in: HSInsteon, version: 1.0.0.6
5/11/2014 12:02:38 AM ~!~Plug-In~!~Found plug-in: HSTouch Server, version: 3.0.0.22
5/11/2014 12:02:38 AM ~!~Plug-In~!~Found plug-in: Insteon Thermostat, version: 3.0.0.7
5/11/2014 12:02:38 AM ~!~Startup~!~Initializing Plug-Ins
5/11/2014 12:02:39 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1042
5/11/2014 12:02:39 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1043
5/11/2014 12:02:39 AM ~!~Info~!~Plug-in ADIO-100 has connected successfully
5/11/2014 12:02:40 AM ~!~Plug-In~!~Finished initializing plug-in ADIO-100
5/11/2014 12:02:40 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1044
5/11/2014 12:02:40 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1045
5/11/2014 12:02:40 AM ~!~Info~!~Plug-in HSInsteon has connected successfully
5/11/2014 12:02:41 AM ~!~Plug-In~!~Finished initializing plug-in HSInsteon
5/11/2014 12:02:41 AM ~!~ADIO-100 ERROR~!~Expected Response from Unit Not Received For Command z
5/11/2014 12:02:41 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1046
5/11/2014 12:02:41 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1047
5/11/2014 12:02:41 AM ~!~Info~!~Plug-in HSTouch Server has connected successfully
5/11/2014 12:02:42 AM ~!~Plug-In~!~Finished initializing plug-in HSTouch Server
5/11/2014 12:02:42 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1048
5/11/2014 12:02:42 AM ~!~Info~!~Remote application or plugin has connected: 127.0.0.1:1049
5/11/2014 12:02:42 AM ~!~Info~!~Plug-in Insteon Thermostat has connected successfully
5/11/2014 12:02:42 AM ~!~Warning~!~Cannot find requested INI file: C:\Program Files\HomeSeer HS3\Config\hspi_insteon_thermostat.ini
5/11/2014 12:02:42 AM ~!~Insteon Thermostat~!~---------------------------------------------------------------------
5/11/2014 12:02:42 AM ~!~Insteon Thermostat~!~Starting Up... Insteon Thermostat plug-in version = 3.0.0.7
5/11/2014 12:02:42 AM ~!~Insteon Thermostat~!~hs.Version = 3.0.0.68
5/11/2014 12:02:42 AM ~!~Insteon Thermostat~!~hs.InterfaceVersion = 4
5/11/2014 12:02:42 AM ~!~Insteon Thermostat~!~hs.PluginLicenseMode = Registered. Thank you!
5/11/2014 12:02:43 AM ~!~Plug-In~!~Finished initializing plug-in Insteon Thermostat
5/11/2014 12:02:43 AM ~!~Web Server~!~Local IP address (subnet) is: 192.168.1.4 (255.255.255.0)
5/11/2014 12:02:43 AM ~!~Web Server~!~UPNP Discovery started
5/11/2014 12:02:44 AM ~!~Web Server~!~Web Server started on port 81
5/11/2014 12:02:44 AM ~!~Startup~!~Creating ASP.NET application host...
5/11/2014 12:02:46 AM ~!~Startup~!~Start automation engine...
5/11/2014 12:02:46 AM ~!~Startup~!~Initializing Speaker Client Interface
5/11/2014 12:02:46 AM ~!~Speech~!~Listening for remote speaker connections on port 10401
5/11/2014 12:02:46 AM ~!~Startup~!~HSSentry is disabled in Setup, sentry will not be started.
5/11/2014 12:02:46 AM ~!~Startup~!~Starting Event Scheduler...
5/11/2014 12:02:47 AM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer Energy database C:\Program Files\HomeSeer HS3\Data\Energy\Energy.hsd
5/11/2014 12:02:47 AM ~!~Startup~!~Updater services starting...
5/11/2014 12:02:47 AM ~!~Startup~!~Starting DDNS service...
5/11/2014 12:02:48 AM ~!~Info~!~Starting speaker client...
