HVAC's disappearing
  • HVAC's disappearing
    Hi,
    For some reason, when I restart HS3, 2 of my 3 HVAC's are disappearing.
    I recreate them and all is well, but then after restart they are gone again. The devices stay, but they are gone in the configuration pages.
    -BD
    Really... no response? I can understand for a free plugin but you did take $$ for it...
    -BD
      I could make this a monthly exercise I suppose?!
      Or... you could answer?
      -BD
        Respectfully, this is a hobby. The majority of $ (after HS takes their cut and taxes) have gone to the hardware and licensing of previous software needed to test this plugin. My goal with this was to support the Insteon investment I already had under HS3 since the HS2 plugin was not going to be ported.
        That said, I'm sorry that you're seeing this behavior. The plugin syncs up the devices it finds configured in HS3 with those defined from the saved config file. I only run with 1 HVAC but it should support multiple without issue. Of course, bugs are possible. Please provide your HS3/config/hspi_insteon_thermostat.ini after you have it working (HS3 reboot and reconfiguring your additional HVACs) and also your HS3/logs/InsteonThermostatDebug.log so I can try to see what's going on.
        I will likely look at this as I take time off work for Christmas and New Years so it may be a short while before I can help find the cause.
        HS 3.0.0.435 (PRO)
        Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
        Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
        Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
        http://www.kazteel.com/
          Please check the version of HS3 you're running. Another user had issues with disappearing programs across HS3 reboots and it turned out to be the HS3 version.
          http://board.homeseer.com/showthread.php?t=171605
          The INI routines I use are part of the HS3 API and are straight forward but I know there have been a lot of work on them by HST due to Linux compatibility etc.
          HS 3.0.0.435 (PRO)
