Great job on this plugin!
The plugin already has a counter for cumulative time on heat and/or cold. So I assume, at the end of each heating|cooling period, the plugin adds the elapsed time for the heating|cooling period just finished to the global counter.
Would it be possible to include an extra step? When writing to the log the entry "... turning off HEAT|COLD", it would be great if the plugin appended the elapsed time for that period; for example "... turning off HEAT|COLD after 63 minutes".
I currently extract entries from the log to produce a visual graph of heating|cooling profile. This requested feature would greatly simplify my life.
By the way, this would be a good candidate for a graph, similar to the energy graph. Too bad the energy graph doesn't allow different input parameters: al that would be needed is replacing 'Kwh' by 'minutes On for period'.
