Nathan,
I've sporadically seen some error messages regarding the 2441TH (see below).
Since both the From/To addresses are present, I assume these messages are "IM to host" messages and not "device to device" messages. If so, there should be a 0x02 prefix followed by the IM command (0x50, 0x51 ...).
I can recognize the 2441TH's address (20 47 DD) and my Hub's (1E 9E CF in some messages). Cmd1, Cmd2 and Flag fields are all over.
But what's consistent is that 0x01 at the start followed by the 2441TH's address. It seems odd that part of the message is stable and the rest erratic. What troubles me is that these thermostats are RF which should be more reliable than power line. So what's the issue with transmission?
Not a big deal, but wondering if I have an RMA potential?
Anybody else seeing these?
2014-11-30
Nov-30 02:31:40 Insteon Thermostat Error Invalid ACK received from plugin. Aborted message = ACK 6A 20 01 20 47 DD 1E 9E CF 0F 6A 32
Nov-30 02:31:43 Insteon Thermostat Error 2441TH - Unexpected device type requested for polling.
Nov-30 07:56:12 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E 00 00 00 00]
Nov-30 07:57:25 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E CF 05 00 00]
Nov-30 08:07:28 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E CF 00 00 00]
Nov-30 08:14:25 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E 00 00 00 00]
Nov-30 08:42:22 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E 00 00 00 00]
2014-12-01
Dec-01 22:29:25 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 11 00 00 00 00 00]
2014-12-02
Dec-02 07:11:36 Insteon Thermostat Error Direct Message unhandled cmd1=EF raw data [01 20 47 DD 11 02 50 13 EF 65]
Dec-02 14:52:40 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 00 00 00 00 00]
2014-12-05
Dec-05 19:18:39 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E 00 00 00 00]
2014-12-08
Dec-08 21:24:03 Insteon Thermostat Error Direct Message unhandled cmd1=00 raw data [01 20 47 DD 1E 9E CF 05 00 00]
2014-12-09
Dec-09 16:54:23 Insteon Thermostat Error Invalid ACK received from plugin. Aborted message = ACK 6A 20 01 20 47 DD 1E 9E CF 0F 6A 32
Dec-09 16:54:26 Insteon Thermostat Error 2441TH - Unexpected device type requested for polling.
2014-11-30
2014-12-01
2014-12-02
2014-12-05
2014-12-08
2014-12-09
