The humidity and temperature updates are always double hits (two entries for each occurrence). Is this normal?
Also, are these updates initiated by the thermostat, or as a result of the auto refresh parameter in the config page, which is now set for 20 sec. I don't recollect if that number was the default, or a value I put in there. Seems excessive though.
BTW, this plug-in is fantastic, doing everything I need it do do, and more. thanks.
