Originally posted by tim.palmer
View Post
Today while looking at the problem with VB scripts on Linux, I also found the actual root cause of the problem we had with the System.Data.SQLite.dll. Turns out the file HSPI_INSTEON_THERMOSTAT.exe.config is supposed to point to the right directory to pickup DLL files like that but it was using Bin/ instead of bin/ and on Linux that failed due to case sensitivity. I have fixed this in the latest beta version 3.0.6.1. You should be ok with our work around solution of putting the DLL file in the main HS3 folder for now but wanted you to know there's a permanent fix now.
Nathan
