Log and Error Questions
    Previously in HS2 I pooled my Tstats ever 6 mins cause I graph the data in a database.
    Over the last week I have started to switch over to HS3 and noticed errors in the Log.
    What might these errors below mean?
    also
    When I create a event for pooling, I check do not log the event box. While it doesn't log the actual event, it does fill my log up with the values it returns from the Tstats. Is this expected?
    Charlie
    HSPro: 3.0.0.194
    PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
    HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
    Excuse me, I forgot to post the Errors.
    Here they are,
    Mar-25 11:54:19 PM Insteon Thermostat Error Error in SendPollRequestsSystem.Exception: Unable to determine thermostat type, Insteon device category (devcat) is not set yet. at HSPI_INSTEON_THERMOSTAT.utils.isSmarthomeWirelessDEVCAT(Coll ection tstat) at HSPI_INSTEON_THERMOSTAT.Insteon.SendPollRequests(Collection tstat, Boolean pollMode, Boolean pollTemp, Boolean pollSet, Boolean pollHum)
    HSPro: 3.0.0.194
      If this was working as expected there shouldn't be any logs from your event. What you are seeing is the plugin thinks it doesn't know what device category (devcat) applies to your specific thermostat. This is something that is discovered when the plugin starts up or when you add a new thermostat via the config page. It has to know the devcat so it can adjust what commands it sends. I will have to experiment with mine and see if I can reproduce a similar scenario.
      HS 3.0.0.435 (PRO)
      Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
      Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
      Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
      http://www.kazteel.com/
        Were running similar Tstats. Mine is a T1900 with the Insteon adapter, so I get an extra value of Humidity.
        If u need me to do something, pls let me know.
        HSPro: 3.0.0.194
          Also another issue I have is, the plugin keeps changing the HVAC modes from off to cool and such forth. I do have some events that turn the units on/off or change set temps, but none that match these times or behaviors.
          Or are the below logs just the 2 Ton HVAC unit hitting its upper dead-band, and activating the compressor to bring the temp down and logging its activity?
          Heres the logs for the above.
          Mar-27 4:17:04 PM Insteon Thermostat 2 Ton switching from Off to Cool
          Mar-27 4:17:04 PM Insteon Thermostat 2 Ton calling for COOL
          Mar-27 3:23:52 PM Insteon Thermostat 2 Ton switching from Cool to Off
          Mar-27 3:23:52 PM Insteon Thermostat 2 Ton turning off COOL after 6 minutes.
          Mar-27 3:17:17 PM Insteon Thermostat 2 Ton switching from Off to Cool
          Mar-27 3:17:17 PM Insteon Thermostat 2 Ton calling for COOL
          Mar-27 2:45:33 PM Insteon Thermostat 2 Ton switching from Cool to Off
          Mar-27 2:45:33 PM Insteon Thermostat 2 Ton turning off COOL after 7 minutes.
          Mar-27 2:38:26 PM Insteon Thermostat 2 Ton switching from Off to Cool
          Mar-27 2:38:26 PM Insteon Thermostat 2 Ton calling for COOL
          Mar-27 2:08:42 PM Insteon Thermostat 2 Ton switching from Cool to Off
          Mar-27 2:08:42 PM Insteon Thermostat 2 Ton turning off COOL after 9 minutes.
          Mar-27 1:59:37 PM Insteon Thermostat 2 Ton switching from Off to Cool
          Mar-27 1:59:37 PM Insteon Thermostat 2 Ton calling for COOL
          HSPro: 3.0.0.194
            Hello,
            I was wondering if it would be possible to get the lower temperature values from the external probe to show up correctly in both Fahrenheit and Celsius. Currently all that it shows on my screen (Only when it hits below the 0C) it not longer displays the correct value (for example; if the external probe reads -11F on the thermostat the device Value in HS3 is 244 - which show up blank or unknown to Homeseer.
            I've tried playing around with some of the settings but i couldn't get a proper negative value to display (in Fahrenheit or in Celsius).
            I'm running;
            > A Hometroller S5 with HS3 (Latest updates installed v.3.0.0.152 WinXp)
            > Using the latest updated version of the Insteon thermostat Plugin provided in HS3
            > Using the Serial Insteon PLM
            Evan G
              Still having Errors
              Been having the same issues as before with no change.
              Here is the log snips where you will see the 4 Ton HVAC unit working then it just disappears due to errors.
              Apr-27 12:17:55 PM Insteon Thermostat Error WSPBP: Unable to determine thermostat type, Insteon device category (devcat) is not set yet.
              Apr-27 12:17:35 PM Insteon Thermostat Error WSPBP: Unable to determine thermostat type, Insteon device category (devcat) is not set yet.
              Apr-27 12:17:15 PM Insteon Thermostat Error WSPBP: Unable to determine thermostat type, Insteon device category (devcat) is not set yet.
              Apr-27 12:16:36 PM Insteon Thermostat Error Error rendering thermostat for 4 Ton - Unable to determine thermostat type, Insteon device category (devcat) is not set yet.
              Apr-27 12:14:48 PM Insteon Thermostat 2 Ton switching from Off to Cool
              Apr-27 12:14:48 PM Insteon Thermostat 2 Ton calling for COOL
              Apr-27 11:46:00 AM weatherXML Error downloadFile: mapDownload0 from: . Error: An exception occurred during a WebClient request.
              Apr-27 10:58:57 AM Insteon Thermostat 4 Ton switching from Cool to Off
              Apr-27 10:58:57 AM Insteon Thermostat 4 Ton turning off COOL after 110 minutes.
              Mark has been helping with a what looks to be a general issue with the Insteon Network as well (Here's the Tread on that)
              Also here is the Status Page where its gone.
              Do you think this is something thats happening within your plugin?
              Charlie
              HSPro: 3.0.0.194
                Bumping this thread due to my issue is still active.
                Please advise.
                Charlie
                HSPro: 3.0.0.194
                  The thermostat devcat (Device Category) is set when the plugin starts up and requests it from the existing thermostats already configured. Or, it's set when a new thermostat is added via the web config page. Once the request / reply is made, the devcat is never removed from the thermostat so I'm unsure how you are getting this sequence to happen.
                  I suggest after this error happens, go check the Insteon Thermostat web config page under Thermostats tab and see what is in the square brackets under the 4 ton (or whichever has the error). When correctly working it should show something similar to: VenstarT1800 [0503,95,2]
                  You might try stopping and restarting the Insteon plugin after this error happens and see if things return to normal. This will cause a clean reconnect to the thermostats.
                  I'm not sure if any of the Insteon problems you mentioned in the other thread could somehow be related. Not sure how, as the devcat is a set once at beginning and done.
                  You'll note from my footer I am still back on 3.0.0.96. I've found this version stable for my use and have seem way to many stability issues in newer HS3 versions to consider upgrading myself yet. I may have to give it a shot on my test machine however to see if I can reproduce this strange behavior. I'll need to ponder this some more.
                  HS 3.0.0.435 (PRO)
                    I've been having a ton of issues with this plugin/connectivity to my ventstar thermostats as well. Seems like 1 or 2 of my 3 work, but its inconsistent and they seem to change every boot up. I dont think ive ever had all 3 function correctly especially upon reboot.
                    I know there's been a few releases to mark's insteon plugin, and HS3 since you made this plugin available. I can definitely help try to debug but it sure seems that enough of us are having instability issues to warrant some proactive debugging/research by the dev.
                    Please let me know how i can help.
                    Toby
                    HS 3.0.0.199 Pro/Insteon 3.0.5.20/3 Venstar Insteon Therms / Insteon Thermostat 3.0.2.2 / DirecTV 3.0.0.14 / OpenSprinkler 2.0.5.21 / ITunes DAAP 3.0.0.23/ UltraM1G3 3.0.5437.37424/ UltraWeatherbug3 /HSTouch Svr 3.0.0.68/Zwave 3.0.1.25/Ultramon3/Global Cache 5.0.0.17/Various BLXXX Plugins.
                      Here's simple delete of all 3 therms, then adding one back. I get this error when its trying to update links (using button)
                      May-31 10:15:25 PM Insteon Thermostat Error East T1 : Problem Writing links to theremostat
                      May-31 10:15:25 PM Insteon Thermostat TransmitInsteon: [East T1] [1F] [2F] [00] ((([00] [02] [0F] [D7] [08] [A2] [EF] [2A] [DD] [7A] [00] [00] [00] [CF])))
                      May-31 10:15:25 PM Insteon Thermostat TransmitInsteon: [East T1] [1F] [2F] [00] ((([00] [02] [0F] [DF] [08] [E2] [04] [2A] [DD] [7A] [00] [00] [00] [72])))
                      May-31 10:15:25 PM Insteon Thermostat TransmitInsteon: [East T1] [1F] [2F] [00] ((([00] [02] [0F] [E7] [08] [E2] [03] [2A] [DD] [7A] [00] [00] [00] [6B])))
                      May-31 10:15:25 PM Insteon Thermostat TransmitInsteon: [East T1] [1F] [2F] [00] ((([00] [02] [0F] [EF] [08] [E2] [02] [2A] [DD] [7A] [00] [00] [00] [64])))
                      May-31 10:15:25 PM Insteon Thermostat TransmitInsteon: [East T1] [1F] [2F] [00] ((([00] [02] [0F] [F7] [08] [E2] [01] [2A] [DD] [7A] [00] [00] [00] [5D])))
                      May-31 10:15:25 PM Insteon Thermostat TransmitInsteon: [East T1] [1F] [2F] [00] ((([00] [02] [0F] [FF] [08] [E2] [EF] [2A] [DD] [7A] [00] [00] [00] [67])))
                      May-31 10:15:25 PM Insteon Thermostat East T1 : Writing links to theremostat
                        Were still having issues but I'm haven't had time to take or try on what u wrote above.
                        I was thinking of adding events to restart the plugins, but thats a very bandaid approach.
                        HSPro: 3.0.0.194
                          CharlieWayne and I are having the exact same problem. I believe DEVCAT isnt functioning as you expect it should be (possibly getting overwritten every start of the plugin/hs?
                          Its that hot time of the year and right now I am manually adjusting 3 therms. Any help you can provide is appreciated.
                          Ill PM as well.
                            Kuntakitay,
                            Is there a trigger in events so that we can tell if one of the tstats are not responding?
                            If so try and construct an event with the tstat not responding and an action of restarting the plugins.
                            I'm away till next week then I can test with mine, well at least till this Dev can fix this problem.
                            HSPro: 3.0.0.194
                              Sorry for the delay guys. Graduation season / family / vacation.
                              I have upgraded my DEV system to the latest HS3 3.0.0.181 and Mark's latest 3.0.5.20 and now have seen at least one occurrence of the devcat issue. I will need to spend some quality debugging time with this and get back with you. This definitely appears to be some issue related to those upgrades.
                              HS 3.0.0.435 (PRO)
