I am getting errors in the log when I try and use +/- to increase or decrease the setpoint temperature from the HS3 Device List page.
Aug-15 3:54:51 PM Insteon Thermostat Error SetCoolSetpoint: Cool Setpoint has to be within the low/high bounds as configured and greater than the heat setpoint
Aug-15 3:54:51 PM Device Control Device: Insteon Thermostats South Hallway Cool to + (251) by/from: CAPI Control Handler
Aug-15 3:54:48 PM Insteon Thermostat Error SetCoolSetpoint: Cool Setpoint has to be within the low/high bounds as configured and greater than the heat setpoint
Aug-15 3:54:48 PM Device Control Device: Insteon Thermostats South Hallway Cool to + (251) by/from: CAPI Control Handler
Aug-15 6:15:08 PM Insteon Thermostat Error Error during CAPI request - Arithmetic operation resulted in an overflow.
Aug-15 6:15:08 PM Device Control Device: Insteon Thermostats North Hallway Cool to + (251) by/from: CAPI Control Handler
If I change the setpoint using the dropdown from the plugin's thermostat status page, it works fine and there are no errors.
HS3 version - 3.0.0.194
Plugin version - 3.0.2.2
