I'm glad the update worked this time. I can see the new logging and the SQLLite errors are gone.
Can you confirm that the heat setpoint is somehow really 0 ? The heatLow is 30 per your startup log so I'm surprised at how/why it would come back with a 0. Here's a trimmed version of my log when I used the + to increase my cool setpoint andyou can see my heat setpoint is 66.
And here's s snip of my device home screen where you can see that heat setpoint is 66.
I wonder if you might try deleting the heat setpoint HS3 device for the thermostat you're trying to update then stop/restart the plugin so it recreates the device then try using the + / - again ?
Nathan
Aug-17 8:28:33 PM Insteon Thermostat SetCoolSetpoint: VenstarT1800 Cool SetPoint = 79 Aug-17 8:28:33 PM Insteon Thermostat SetCoolSetpoint: VenstarT1800 set cool setpoint to 79 Current cool setpoint = 78 Current heat setpoint = 66 Aug-17 8:28:33 PM Device Control Device: Thermostats Insteon VenstarT1800 Cool to + (251) by/from: CAPI Control Handler Aug-17 8:24:21 PM Insteon Thermostat VenstarT1800 Humidity = 53 Aug-17 8:11:07 PM Insteon Thermostat VenstarT1800 Temp = 73
Nathan
