From my 5 Insteon thermostats. 4 are used for heating (baseboard hot water radiators) and 1 is used for AC (central air). All 5 have devices in HS3 for both heating and cooling. Is there a way to simplify this - getting rid of the devices for cooling for the thermostats used for heating only, etc.? HS3 doesn't bother me too much with the extra devices but I ran in the following issue. I have all 5 thermostat's controls on 1 page in HSTouch Designer for my iPhone HSTouch (see attached screen capture). Real estate on that is precious. I was able to create custom Thermostats Templates by putting all the controls in a group in HSTouch Designer (with some difficulties of copying stuff, but success at the end). Rather nice once done because the template when copied onto a screen brings up a dialog to change the thermostat for each device and changes the programming to that thermostat specifically (had to change the title text box only). The 1st button on the left for each thermostat shows the mode of the thermostat and the button should toggle between HEATING and OFF for heat-only thermostats and COOLING or OFF for the AC thermostat. Instead, pressing this button goes through all the other mode possibilities as well. How do I toggle just between 2 of these modes? I thought about using a script but don't know how.
Rene
Rene
