Nathan,
I was following your posts over on Mark's Insteon Plugin thread related to testing with the Hub 2. As I mentioned there, I also took the plunge. It appeared that everything worked with the exception of 1 of my 3 Tstats did not come up successfully. The other 2 worked right away after restarting the plugin to pickup the new Interface ID and updating the Tstat links. For the one Tstat that didn't work, I had to delete it from the plugin, reset the 2441V to factory and add it back in. From that point, it worked fine.
I am doing some troubleshooting with Mark, and he sent me a new version to test. As soon as I restarted HS3 with the new Insteon Plugin version, that same Tstat won't come up again. It appears that I will have to remove, reset and re-add again. There is no devcat information for that Tsta and many of these errors:
Dec-22 9:46:16 AM Insteon Thermostat Error Post-startup timer to check for thermostat DEVCAT: Upstairs still missing DEVCAT after 13 run(s). Requesting protocol again.
Dec-22 9:44:16 AM Insteon Thermostat Error Post-startup timer to check for thermostat DEVCAT: Upstairs still missing DEVCAT after 12 run(s). Requesting protocol again.
I'm not sure why 2 work fine and one always fails. Is there anything that I can try?
