I am currently in the trial period and testing of this plugin to see if it will allow me to finally cut the cord from HS2. For the most part I have been able to get everything I need working except 1 key piece for me.
I use a custom HSTouch project with a Climate Control section. In HS2 I was able to reliably pull in the current running state of the HVAC system (ie. heating, cooling, off, ect...) using the Sage Insteon plugin with my Venstar T1800 thermostat with the 2441V RF adapter but with this plugin I am having some issues. As you can see below the Device page of HS3 show the "HVAC Mode" correctly but within HSTouch the 'text' value is not populating. I can see the 'Image' and 'value' data points but not the 'text' which is what I need for my custom HSTouch project.
Any thoughts on what to check for to get this working?
