I'm currently running the latest version (3.0.5.3) of the plugin and the response back to HSTouch seems to either not be working or is very delayed.
If I use the Plugin's WEB Control or the Insteon Thermostat Status page, when changing temperatures, the updates are almost instantaneous. When using HSTouch, the entire experience of changing temperature values and temperature reporting is either slow or does not happen at all. I have tried using both the default Homeseer thermostat template and the one provided with the plugin with the results being the same.
Is anyoe else experiencing issues like this?
Judd
Judd
