error on console
    error on console
    I just noticed I am getting this error on the console of my HS3
    everything seems to be working fine.
    BUT I would like to get it fixed please
    Look in your HS3 directory and see if you have two copies of HSPI_INSTEON_THERMOSTAT.exe
    C:\Program Files (x86)\HomeSeer HS3
    should only have
    HSPI_INSTEON_THERMOSTAT.exe.config
    I'm wondering if during the last time you updated it, perhaps windows couldn't delete the older one and now you have more than one .exe in there?
    HS 3.0.0.435 (PRO)
    Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
    Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
    Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
    http://www.kazteel.com/
      That was it..
      However it was a .OLD application, so I looked right past it..
      But once I deleted that the error went away.. thanks so much
      Fred
        This was the first time I had heard of this error. Google helped uncover some old posts in other plugins where this happened. All plugins use the HS3 install mechanism. I can only speculate that perhaps virus scanning software or something similar still had a handle open to the old version while the new one was installed. Glad you were able to find/fix it by removing the old version.
        Nathan
        HS 3.0.0.435 (PRO)
          Wow that's weird..
          well I'm glad it was that easy..
          thanks for the help.
          also cant be antivirus, I am using a homtroller Pro S6 from homeseer..
          so there is no antivirus on it as far as I know.. I didn't install anything
          but either way,... the error is gone.
          thanks so much
          love when its that simple
