Problems with Proliphix NT150h
  • Problems with Proliphix NT150h
    Hi,
    I've tried for hours to get the IPThermostat plugin to work with my Proliphix NT150h. I've upgraded to 3.0.5 on the thermostat and 3.4.5.0 for the IPThermostat plugin.
    I consistently receive the following errors below.
    If I run the MIB URLs I get the following responses:
    http://192.168.27.9:80/get?OID4.1.13=:
    OID4.1.13=691&
    http://192.168.27.9:80/get?OID4.1.5=:
    OID4.1.5=680&
    I know for certain that the username and password are correct despite what the logs seem to indicate.
    It appears that the thermostat won't appear under devices in HomeSeer because of these errors so I'm stuck.
    Any idea what could be happening?
    Much appreciated!
    Jan-05 1:50:18 AM IPThermostat ERROR: PollProliphix: Cannot query http://192.168.27.9:80/get?OID4.1.5=: Conversion from string "" to type 'Long' is not valid.
    Jan-05 1:50:18 AM IPThermostat ERROR: DoGet --> Communication error: Error getting response stream (ReadDone2): ReceiveFailure, at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) <0x73780720 + 0x00164> in :0 at System.Net.HttpWebRequest.GetResponse () <0x7377a2d0 + 0x00067> in :0 at HSPI_IPTHERMOSTAT.PROLILPHIX.doGET (System.String url, System.String username, System.String password) <0x72af95d8 + 0x00433> in :0
    Jan-05 1:50:18 AM IPThermostat ERROR: DoGET --> Unable to communicate with PROLIPHIX. Are you sure the username and password are correct?
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Test1
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Entering DoGet
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Current Temperature = 19.6666666666667
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Test3
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Test2
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = 1234
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = admin
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Icon =
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Type = IP Thermostat
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat brand = PROLIPHIX
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat name = Proliphix Thermostat
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostate ID = 1
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Network = 1
    Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix HS_REF = 0
    Jan-05 1:50:18 AM IPThermostat DEBUG1: PollProliphix: Entering
    Jan-05 1:49:48 AM IPThermostat ERROR: PollProliphix: Cannot query http://192.168.27.9:80/get?OID4.1.13=: Conversion from string "" to type 'Long' is not valid.
    Jan-05 1:49:48 AM IPThermostat ERROR: DoGet --> Communication error: Error getting response stream (ReadDone2): ReceiveFailure, at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) <0x73780720 + 0x00164> in :0 at System.Net.HttpWebRequest.GetResponse () <0x7377a2d0 + 0x00067> in :0 at HSPI_IPTHERMOSTAT.PROLILPHIX.doGET (System.String url, System.String username, System.String password) <0x72af95d8 + 0x00433> in :0
    Jan-05 1:49:48 AM IPThermostat ERROR: DoGET --> Unable to communicate with PROLIPHIX. Are you sure the username and password are correct?
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Test1
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Entering DoGet
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = 1234
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = admin
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Icon = Proliphix-NT.jpg
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Type = IP Thermostat
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat brand = PROLIPHIX
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat name = Proliphix NT150 Thermostat
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Test3
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Test2
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostate ID = 1
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Network = 1
    Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix HS_REF = 0
    Jan-05 1:49:48 AM IPThermostat DEBUG1: PollProliphix: Entering
    Can you try this version to see if it solves your problem --> https://www.dropbox.com/s/elij1wp1pj...OSTAT.exe?dl=0
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Hi Rien du Pre,
      Thank you so much for your timely assistance.
      I probably should have mention this before, I'm using
      a HomeTroller Zee S2. Looks like the file, exe, you provided on DropBox is for the Windows HS3 version?
      Any chance a Linux plugin can be created for testing on the Zee S2?
      -Tom
