Duplicated devices with Anna
  • Duplicated devices with Anna
    I've two strange problems.
    I use a Anna thermostat in combination with the IPThermostat plugin.
    It works fine but sometimes I get extra devices. If I delete the one that are not updated the events loose their connection with the original devices. It all get messed up.
    The second 'problem' is that the heatpoint is in Fahrenheid instead of Celsius.
    Any ideas what's causing this?
    Firware Anna 1.8.20
    Plugin 3.4.5.0
    HS3 Standard Edition 3.0.0.368
    I don't know why the thermostats are being recreated. and unfortunately I cannot test it because I have nog ANNA available anymore.
    The Fahrenheit issue is caused by HomeSeer. Go to your HomeSeer settings and set the temperature scale to Fahrenheit and then back to Celsius
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Thanks for the reply Rien.
      I've changed the Celsius to Fahrenheid and back. It's Celsius now but the value is still in Fahrenheid.
        Rien,
        Can you please deploy a version of the plug-in where the auto learning can be or is disabled. I'm getting crazy by Homeseer adding multiple thermostats every time I restart.
        https://s33.postimg.cc/8salt9y33/Knipsel.jpg
        I've also have still the problem that Homeseer is showing the themparature in Fahrenheid.
        Can you please have a look at these issues?
        Thanks!
