Problems with ANNA
  • Problems with ANNA
    Hi,
    I just installed the ANNA and get the following error message:
    apr-19 21:24:00 IPThermostat DEBUG1: PollANNA Thermostat: Increased failed poll counter for '192.168.1.91' to 4
    apr-19 21:24:00 IPThermostat ERROR: PollANNA: Cannot query : Input string was not in a correct format.
    apr-19 21:24:00 IPThermostat DEBUG3: Entering DoGet
    apr-19 21:24:00 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA Thermostate ID = 1
    apr-19 21:24:00 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA Network = 3
    apr-19 21:24:00 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA HS_REF = 0
    apr-19 21:24:00 IPThermostat DEBUG3: Source server is:192.168.1.91
    apr-19 21:24:00 IPThermostat DEBUG1: PollANNA: Entering
    apr-19 21:23:30 IPThermostat DEBUG1: PollANNA Thermostat: Increased failed poll counter for '192.168.1.91' to 3
    apr-19 21:23:30 IPThermostat ERROR: PollANNA: Cannot query : Input string was not in a correct format.
    apr-19 21:23:30 IPThermostat DEBUG3: Entering DoGet
    apr-19 21:23:30 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA Thermostate ID = 1
    apr-19 21:23:30 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA Network = 3
    apr-19 21:23:30 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA HS_REF = 0
    apr-19 21:23:30 IPThermostat DEBUG3: Source server is:192.168.1.91
    apr-19 21:23:30 IPThermostat DEBUG1: PollANNA: Entering
    apr-19 21:23:01 IPThermostat DEBUG1: PollANNA Thermostat: Increased failed poll counter for '192.168.1.91' to 2
    apr-19 21:23:01 IPThermostat ERROR: PollANNA: Cannot query : Input string was not in a correct format.
    apr-19 21:23:00 IPThermostat DEBUG3: Entering DoGet
    apr-19 21:23:00 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA Thermostate ID = 1
    apr-19 21:23:00 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA Network = 3
    apr-19 21:23:00 IPThermostat DEBUG3: ANNA Thermostat information retreivement -- ANNA HS_REF = 0
    apr-19 21:23:00 IPThermostat DEBUG3: Source server is:192.168.1.91
    apr-19 21:23:00 IPThermostat DEBUG1: PollANNA: Entering
    Plugin vs 3.4.0.0
    HS3 Standard Edition 3.0.0.258 (Windows)
    The devices are not created. What's going wrong?
    Thanks in advance!
    Jos
    SOLVED!
    Updated ANNA to 1.1.7 and HS3 added the three devices at once.
      Dat klopt, deze versie heeft de uitgebreide API die nodig is voor de plugin.
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
