Hi,
Please could you consider updating the plugin to pull a new parameter from the hub?
The Heatmiser stack has a 'profile' option which allows the user to create a different schedule to be recalled at will, this is called 'profiles' and exists at thermostat context level. I use this a lot but I cannot control it through HS3.
Typical use case for me is 'Downstairs Hall Normal' which turns heating down through the day & 'Downstairs Hall Working From Home' which keeps the heating on through the day.
If this could be exposed through HomeSeer I could create logic which said something like
at 08.00 Mon to Fri
if house alarm status is 'armed'
set 'downstairs hall profile' to 'Downstairs Hall Normal'
else set 'downstairs hall profile' to 'Downstairs Hall Working From Home'
Look forward to your response.
Simon
at 08.00 Mon to Fri
Simon
