Just to let you know I am now running 5 heatmisers against your plugin with no issues. I am finally updating my heating system to 12 zones over the summer and will report back when 12 heatmisers are integrated into homeseer via your plugin.
I have been collecting them quite cheap on ebay over the last few months!
Hi
I have finally been testing your plugin and I have to say it is fantastic. Really easy to use and really clear.
I do have 1 question. I added 2 thermostats by mistake, I was not patient enough to wait for the stats to be added. I would like to remove these stats but dont seem to be able to do so.
I have tried removing the stat details but then pressing the update buttton. I have also tried editing the .ini file but this appears to be created each time.
Could you please point me in the right direction to remove unwanted stats
Hi
Thanks for the kind words. Good idea, I have updated the manual so anyone installing the plug-in from here on in will have the instructions on deleting a thermostat.
OK I think I have found a bug.... It's 31 degrees in Sunny Liverpool England
When a heatmiser gets to 25 degrees, the plugin reports 0 degrees.
When its 27 degrees the plugin reports 2 degrees
when its 26.4 degrees the plugin reports 2.4 degrees ?
Make sense ?
This is for temp, floor temp and remote air temp.
I would like to get to 35 degrees reliably in this hot weather as the heatmiser will ? possible ?
Jonathan
Hi Jonathan
I don't think this is going to be too hard to fix but I need a bit of input from you (as I don't use the Heatmiser myself). Please can you switch the debug level for the plug-in to 5 and restart the plug-in.
It will get very chatty and log a lot of info to the HS logfile. However, if you can find the log lines relating to the thermostats where the temperature should have shown as >25 and point them out to me that would be helpful.
The reason is that the log will contain the data returned by the thermostat so I can analyse this and see if there is an issue with the protocol or the way the PI interpretes the data (more likely!).
I managed to dig out my development stat. I can see the problem you are experiencing and I think I have a fix for it. Just need to do a little bit more testing and should have a release out tomorrow.
One small thing the new version keeps creating a new thermostat of 192.168.1.93
Even if I stop homeseer and delete from the izheatmiser config file it recreates and next reboot.
Is it fixable ?
thanks
Jonathan
Hi, I don't see the behaviour you describe. However, please note the entry the ini file: "Thermostats=n" where n is the max number of thermostats you have.
The plug-in will iterate from 1 to n to check if the thermostat root device exists. If it is not there then it will create the missing devices.
If you delete a thermostat then make sure to update this number as well. If you delete a thermostat that is not the last thermostat (e.g. n-2) then you will need to update the thermostat entries as well.
