Is the plugin just for Windows version of HS3 or is it available for Pi Linux O/S
IZHeatmiser Plugin O/S Requirements
Hi, I've not marked it as working under Linux, only because I have not had a chance to test it with Linux yet. However, the analyser suggests it should indeed work under linux.
You can give it a try by copying the izHeatmiser.exe file to the homeseer directory on your linux box and enable the plug-in. Let me know how you get on. Happy to work with you to get it fully working under linux if you are experiencing any problems.Nicolai L
Originally posted by Paul.Giles View PostI see no option in the plugin download menu so not sure how it can be enabled. Is the izHeatmiser.exe file downloadable from somewhere else?
ftp://home.indigozest.net/FTP/HomeSe...er_3_0_0_4.zipLast edited by NicolaiL; December 7, 2015, 04:35 PM.Nicolai L
Downloaded Zip and copied to the HS3 directory. I could then find the plugin & enable. Plugin status showed on, I got extra devices listed & could manage the plugin settings. However it did not seem to work and I got the following in the log file
Dec-09 7:24:42 PM izHeatmiser ERROR Counter: 1 Thermostat count: 1
Dec-09 7:24:42 PM izHeatmiser ERROR Error in Timer function. Error message: Insufficient Space Parameter name: bytes
Dec-09 7:24:01 PM Error Calling SetIOMulti in plugin izHeatmiser:Number overflow.
Dec-09 7:24:01 PM Device Control Device: izHeatmiser izHeatmiser01 izHeatmiser Root to Poll (-10) by/from: CAPI Control Handler
Dec-09 7:23:42 PM Plug-In Finished initializing plug-in izHeatmiser
Dec-09 7:23:42 PM izHeatmiser DEBUG Initialised, up and running ...
Dec-09 7:23:41 PM Info Plugin izHeatmiser has connected. IP:127.0.0.1:59196
Dec-09 7:23:39 PM Plug-In Interface izHeatmiser is running as a trial, 30 days remaining.
Please try the attached version and let me know how you get on. This is updated with the way it handles TCP communication so now it should support linux as well as Windows.
I have tested in both my environments and it seems OK. It would be great to get your feedback as well please.
If this is working I will release it in the main updater (with linux support).Attached FilesNicolai L
