I have version 3.0.1.0 of the Plugin installed on my HS3 ZEE S2 Edition 3.0.0.297 (Linux). I believe there is a newer version of the plugin available but my HS systems shows mu current version as the latest. Is there a manual process to follow to upgrade to the latest version?
IZHeatmiser Plugin Upgrade
Originally posted by Paul.Giles View PostI have version 3.0.1.0 of the Plugin installed on my HS3 ZEE S2 Edition 3.0.0.297 (Linux). I believe there is a newer version of the plugin available but my HS systems shows mu current version as the latest. Is there a manual process to follow to upgrade to the latest version?
Hope this helps.Nicolai L
Sounds like you have an issue with your updater. I have just checked both a Windows and Linux system and both are showing 3.0.1.2 for the Heatmiser plug-in.
Have you pressed the Update Listing button on the Plugins/Manage page? If so, you might need to get HomeSeer involved as this is not an issue with my plug-in as such I think.
Also, have you ever used an Updater_Override.txt file to test out beta plug-ins from other authors? If so, then you will need to remove this file first to get the updater to show the correct listing.Nicolai L
