My Heatmiser plugin suddenly stopped working. It doesn't update temperatures anymore, but the hub itself is working - the Heatmiser app works fine. I tried even reinstalling the plugin, still the same.
The HSPI_izHeatmiserNEO.exe is running, I'm able to change the debug level in settings, I can restart the plugin from command line, no errors.
I wonder if this line is correct?
But when I try to change polling frequency:
Plugin: izHeatmiserNEO Instance: starting... Connecting to server at 127.0.0.1... Host API Version: 3 Connected, waiting to be initialized... InitIO called with parameter port as COM1 In izStd.IniPlugIn Bytes Read: 15 More Data Available Bytes Read: 1 ResponseData Length: 16 Initialised, up and running ...
Posting back to plugin web page Config: Object reference not set to an instance of an object. -> Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
