2 Nest thermostats
  • 2 Nest thermostats
    I just added a mini split and a new nest to control it, it shows up after deauth auth but not the old one that runs the main house ac??
    If both thermostats show up in the same Nest account, they should show up in HS3.
    Note that when adding a new thermostat you shouldn't deauth as this will remove your current Nest devices in HS. The plug-in should pick up the new thermostat automatically and create the corresponding devices.
    Set the log level to Debug, restart the plug-in, and if you still can't see the devices for both your thermostats (after making sure they are not filtered out in the Device management page) please post your logs.
