Nest Devices Won't Install
  • Nest Devices Won't Install
    I have a nest thermosta and I am not able to have the installation work correctly. Only a single device is added. I get the following in the log:
    Oct-06 10:12:53 PM Nest DEBUG data: null
    Oct-06 10:12:53 PM Nest DEBUG event: keep-alive
    I've attached the screen shot.
    This is running on a homeseer SEL running linux.
    The only odd thing about my install is that I have two thermostats registered at nest. I only checked the one at my current house.
    make sure the devices are not filtered out by the Floor and Room filters.
    if that's not the problem, set the log level to debug, restart the Nest plugin, and post your logs here.
      That is what I did in the last email.
      I have log level set to debug
      I did do a reinstall (many actually)
      When I have no devices filtered the only nest device that shows up is the one shown above. (I have 50 UPB devices and a zwave device)
      I just figured out how to filter the log, this shows a couple of laps through the uninstall process.
      ct-07 8:16:35 AM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.UInDFqwWhBuDXSaDf15zoWTtUZFP9Wso0IObsk4pGoM6ok9 I2eq4eXTZLyjvzbUVXr7ChaYHDQD3BN4pIhWwkgibex0SSsmIyqACP8awp1E rtRhVTD09t2kv8yKE21Vq3WNyFLytyEm9KNok', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
      Oct-07 8:15:12 AM Nest DEBUG NestSharp.NestException: oauth2_error authorization code not found at NestSharp.NestClient.GetAccessToken (System.String pin) [0x000b5] in <8a88ebd0928c47baa65ddd32176f6769>:0 at HSPI_Nest.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) [0x0013d] in <111ef61c67414da8b80be505775a6644>:0
      Oct-07 8:14:07 AM Nest INFO Nest Authorization has been revoked
      Oct-06 10:11:52 PM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.YachG0yBIuuXr6NpwV6hpmBBxnpgjvP92Y5QL33mCg3BLzd WD2kHvcU5xtA4F5fvmKlC1yf5QUzGLpEL8rjH7FXUqKOxaSzIv6PXNyqbrnm IgIeYM98uaxW0xNfbFTbewmxmHbizGfkqJGZj', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
      Oct-06 10:11:21 PM Nest INFO Nest Authorization has been revoked
      Oct-06 10:05:53 PM Nest DEBUG NestSharp.NestException: oauth2_error authorization code not found at NestSharp.NestClient.GetAccessToken (System.String pin) [0x000b5] in <8a88ebd0928c47baa65ddd32176f6769>:0 at HSPI_Nest.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) [0x0013d] in <111ef61c67414da8b80be505775a6644>:0
      Oct-06 10:05:50 PM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.2RJkADRjOIFZs41TpfErDcPl04e6ctOS9LBZllcgWKm1VEP AjQk966xx7kOJFwKR8ZzUP3M281hyF1onzmW8e5RHmO5fWf9X0CXAOwarj45 kzCQngaQw1rqF291sgeG9D5iSzEEw2bf2Yt2o', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
      Oct-06 10:05:03 PM Nest INFO Nest Authorization has been revoked
      Oct-06 10:04:35 PM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.WPTYO0ckp4yR5DGjH6yD1R6IRBbpHKQIxtH8Di1X1eTGwlp OsFrX4cktJa7zBUhQxg5vsu375L6qmCOiIP6FikAnvl8yMm57gOoLiU7hQWR YVXmV1rh21ib0hdGaKe7fab4Sg1q6oLkguI3a', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
      Oct-06 10:03:55 PM Nest INFO Nest Authorization has been revoked
      Oct-04 3:16:06 PM Plug-In Finished initializing plug-in Nest
      Oct-04 3:16:06 PM Nest INFO Nest version 3.0.0.28
      Oct-04 3:16:06 PM Info Plugin Nest has connected. IP:127.0.0.1:54528
      Oct-04 3:16:00 PM Plug-In Found plug-in: Nest, version: 3.0.0.28
        please post the debug logs you get when you start the plugin (no need to uninstall - reinstall, just disable- re-enable)
          Oct-07 10:38:00 AM Nest DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.PDK0yLJHWEsfpKhL27ia7RxxcX8gKG0AcoQqT6tacWnw1Yk sheuqx405Lqv5UfzoOxqLQgGXzhqLNTRaHHoDkbzDttrl9Id8RnhCcmGqCnt Xn2K5TWOsNrVGaxlHiVr4G4phI7uR8lMLoAki', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
          Oct-07 10:37:59 AM Plug-In Finished initializing plug-in Nest
          Oct-07 10:37:59 AM Nest INFO Nest version 3.0.0.28
          Oct-07 10:37:58 AM Info Plugin Nest has connected. IP:127.0.0.1:41711
          Oct-07 10:37:52 AM Info Plugin Nest with instance: has disconnected
          Oct-07 10:37:52 AM Nest INFO Shutting Down Nest plugin
          Oct-07 10:37:52 AM Plug-In Shutting down Plug-In: Nest
            Worth noting on this issue:
            1) I have two nest devices registered at nest and when installing I checking this one. This might not be a normal case for you.
            2) Does the communication with the Nest Thermostat happen directly across the network OR does the Nest API go to the internet and then back to the thermostat? It could be possible that I need to go into my router to loosen firewall rules.
              1. The plugin works with multiple nest devices. But what do you mean by "I only checked one"?
              2. All the communication goes to the internet, so please test with no firewall.
              In your logs you should get a response to the first GET request: something like this:
              	DEBUG response=StatusCode: 200, ReasonPhrase: 'OK', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: { Access-Control-Allow-Origin: * Pragma: no-cache Cache-Control: no-store, no-cache, max-age=0, private Content-Type: text/event-stream; charset=UTF-8 }
              and then you should see all the thermostats data
                When I do the initial installation and go to the nest site to get the alpha-numeric string I have two devices listed: the thermostat in the house I'm automating and another thermostat in a different location that is not related to homeseer in any way. I only check the thermostat homeseer should use.
                I checked the rules in the router and all my devices were allowed full access the internet and have no time of day restrictions. Tonight I'll look at this again and use WireShark to sniff around. I should hopefully be able to see what is happening from the SEL since it is hardwired.
                  I did a reset of the Nest and installed it from the ground up again and was able to get everything to work on the first pass through the setup.
                  The only thing I changed was something that came up with my Alexas. The Alexa devices do not work correctly if they are setup on a guest network. In my house I had all my HA gear on the guest network (which I don't use for guests). So yesterday I switched everything over to live on their own non-guest network and everything is working as expected now.
                  Thanks for your help getting me through the troubleshooting process.
                    Not creating devices
                    See log.
                    Oct-29 13:31:44 DEBUG Retrying in 5 seconds...
                    Oct-29 13:31:49 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    File name: 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' ---> System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    File name: 'System.Threading.Tasks, Version=2.6.8.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
                    WRN: Assembly binding logging is turned OFF.
                    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
                    Note: There is some performance penalty associated with assembly bind failure logging.
                    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
                    at FirebaseSharp.Firebase.GetStreamingAsync(String path, DataUpdatedEventHandler updated, AuthRevokedEventHandler revoked)
                    at NestSharp.NestClient.StartMonitoringData()
                    Oct-29 13:31:49 DEBUG Retrying in 5 seconds...
                    Oct-29 13:31:54 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:31:54 DEBUG Retrying in 5 seconds...
                    Oct-29 13:31:59 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:31:59 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:04 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:04 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:09 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:09 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:14 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:14 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:19 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:19 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:24 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:24 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:29 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:29 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:34 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:34 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:39 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:39 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:39 INFO Shutting Down Nest plugin
                    Oct-29 13:32:51 INFO Nest version 3.0.0.28
                    Oct-29 13:32:52 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:52 DEBUG Retrying in 5 seconds...
                    Oct-29 13:32:57 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:32:57 DEBUG Retrying in 5 seconds...
                    Oct-29 13:33:02 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:33:02 DEBUG Retrying in 5 seconds...
                    Oct-29 13:33:07 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:33:07 DEBUG Retrying in 5 seconds...
                    Oct-29 13:33:12 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:33:12 DEBUG Retrying in 5 seconds...
                    Oct-29 13:33:17 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:33:17 DEBUG Retrying in 5 seconds...
                    Oct-29 13:33:22 DEBUG System.IO.FileLoadException: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
                    Oct-29 13:33:22 DEBUG Retrying in 5 seconds...
                    Ty
                    Bob M.
                      Originally posted by rmuziani View Post
                      See log.
                      Ty
                      Bob M.
                      Do you have mainlobby installed on your Homeseer machine?
                      there is a known issue with MainLobby, read this thread: https://forums.homeseer.com/showthre...44#post1245444
                        Yes, I have Mainlobby on the same pc. I removed the lines and the devices got created.
                        Thanks for your help. I will keep you posted,
                        Bob M
