Nest smoke detectors, is this right?
  • Nest smoke detectors, is this right?
    First: Merry xmas
    I installed the plugin a few days back after installing 5 Nest smoke detectors. The install of the plugin went fine. However, isn't there supposed to be some updates coming into the devices in Homeseer? Only the Home/Away seems to update. No errors in the log. I tried reauthorizing the plugin with Nest as well, without any change. This is how it looks after a couple of days:
    Well, the devices values are updated but since the value is 0, which is also the default value for a device the last change time is not updated.
    I don't know if there is any reason behind this or if it is a bug in HS3. But if the devices are updated to another value the last change time will be populated.
      Right, thanks!
        On device configuration, there is also an option to Not update the last change time if the value does not change. It seems I mostly see it default to checked. You might try unchecking it. It is the last config parameter on the first device screen.
