only partially working?
  • only partially working?
    I've had the plug in setup and configured for quite some time(years), however sometime in the last few months it only partially works now. it shows the active status, and the Ambient Temperature, but none of the controls are working, the set points dont change, the mode doesnt change, the fan control doesnt work.
    help?
    and i do get this " WARNING Can't adjust target temperature while structure is set to Away or Auto-away." in the log file. (the nest is not in either mode)
    what is the status of the structure device? Is it Home, Away or Auto-Away?
    Could you provide some debug logs?
      it said home on the device page, as well as on the actual thermostat.
      i power cycled the thermostat, and now it seems to be working properly?!
