Nest devices not updating
  • Nest devices not updating
    Hi All,
    Nest PI been working fine, however, today I have noticed that HS3 nest devices no longer update.
    have re authorised PI and stopped and restarted from "manage" page, still no joy!
    Updated to latest Beta on my HS SEl box but looking at last device update date, these have stopped working prior to this. Any pointers appreciated. Think I am running latest Mono but unsure how to check. Not very familiar with Linux
    Steve
    set the log level to Debug, restart the plugin and post what you have in the logs here.
      Hi Spud,
      below as requested.
      Mar-17 5:37:41 PM
      Nest
      DEBUG System.MissingMethodException: Method 'NestSharp.NestThermostat.get_eco_temperature_high_f' not found. at HSPI_Nest.NestApp.OnNestDataUpdated (System.Object o, NestSharp.NestData data) [0x00094] in :0
      Mar-17 5:37:41 PM
      Nest
      ERROR Method 'NestSharp.NestThermostat.get_eco_temperature_high_f' not found.
      Mar-17 5:37:40 PM
      Nest
      DEBUG Monitoring started.
      Mar-17 5:37:38 PM
      Nest
      DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"DCAZxmy1g568pg3zuoxnBQ_ VumSUMP-v":{"humidity":30,"locale":"en-GB","temperature_scale":"C","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.6.6-4","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiMtjQbZC oA_a89rhPAjLBKgj6J6fiZirIA","device_id":"DCAZxmy1g568pg3zuox nBQ_VumSUMP-v","name":"Lounge","can_heat":true,"can_cool":false,"target_ temperature_c":23.0,"target_temperature_f":73,"target_temper ature_high_c":24.0,"target_temperature_high_f":75,"target_te mperature_low_c":20.0,"target_temperature_low_f":68,"ambient _temperature_c":23.0,"ambient_temperature_f":73,"away_temper ature_high_c":24.0,"away_temperature_high_f":76,"away_temper ature_low_c":17.0,"away_temperature_low_f":63,"eco_temperatu re_high_c":24.0,"eco_temperature_high_f":76,"eco_temperature _low_c":17.0,"eco_temperature_low_f":63,"is_locked":false,"l ocked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_temp_m ax_c":22.0,"locked_temp_max_f":72,"sunlight_correction_activ e":false,"sunlight_correction_enabled":true,"structure_id":" dU3b7uEF7KsIS-zAeU9a6AzOkTKtjFaBvv-IS4IqQpaucRiNaZgCoQ","fan_timer_active":false,"fan_timer_tim eout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Lounge","label":"","name_ long":"Lounge Thermostat","is_online":true,"last_connection":"2018-03-17T17:36:40.521Z","hvac_state":"off"}}},"structures":{"dU3b7 uEF7KsIS-zAeU9a6AzOkTKtjFaBvv-IS4IqQpaucRiNaZgCoQ":{"name":"Sandalwood","country_code":"GB ","time_zone":"Europe/London","away":"home","thermostats":["DCAZxmy1g568pg3zuoxnBQ_VumSUMP-v"],"structure_id":"dU3b7uEF7KsIS-zAeU9a6AzOkTKtjFaBvv-IS4IqQpaucRiNaZgCoQ","wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGe MA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTH qQGf0TJGeMA","name":"Driveway"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTEmTjvca91Q9A":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q9A","name":"Upstairs"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGEY2KDrCGVSQ":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGEY2KDrCGVS Q","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTEQbYDGG26IUQ":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26IUQ","name":"Backyard"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHDWahECEab0A":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHDWahECEa b0A","name":"Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTEB5E9EV7d93w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTEB5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFcdiDipAgT DA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF cdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdS i_g":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT FsTZUOmdSi_g","name":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7 nvpeg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTESyIBY7nvpeg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3M QnKhHOEzrxhFivj_GTHBlgeGDkyHZA":{"where_id":"e4FzI0k3ounJK98 jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGDkyHZA","name":"Office"},"e 4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA":{"whe re_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRs rA","name":"Den"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TGh8lvkqT2xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEz rxhFivj_GTGh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7Yy OQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF mAHn8c7YyOQ","name":"Outside"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4F zI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw":{"where _id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw ","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiMtjQbZCoA_a89rhPAj LBKgj6J6fiZirIA":{"where_id":"e4FzI0k3ounJK98jBApsiMtjQbZCoA _a89rhPAjLBKgj6J6fiZirIA","name":"Lounge"}}}},"metadata":{"a ccess_token":"c.4GY9Qcl9Xe1XdNrKI8EUEdTmqsawPKZL4ccPKseR1feo vJzvgO8V04roCHT9qPKXGnxw2GsUDBWjCU4Bk3H4yOVaiSwBoWTFrJsEzILE bk9bWhrfUXbbTarEdwfNKzh8Ymq3lJqvVMHoi3zE","client_version":5 ,"user_id":"z.1.1.KVO0gW4Ld9/dhV/lBIw9/2FpGQK8i+nWnVWtvwnQ93M="}}}
      Mar-17 5:37:38 PM
      Nest
      DEBUG event: put
      Mar-17 5:37:38 PM
      Nest
      DEBUG polling thread started
      Mar-17 5:37:38 PM
      Nest
      DEBUG status code ok
      Mar-17 5:37:38 PM
      Nest
      DEBUG response=StatusCode: 200, ReasonPhrase: 'OK', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: { Access-Control-Allow-Origin: * Cache-Control: no-store, no-cache, max-age=0, private Pragma: no-cache Content-Type: text/event-stream; charset=UTF-8 }
      Mar-17 5:37:37 PM
      Nest
      DEBUG Method: GET, RequestUri: 'https://developer-api.nest.com/.json?auth=c.4GY9Qcl9Xe1XdNrKI8EUEdTmqsawPKZL4ccPKseR1feovJz vgO8V04roCHT9qPKXGnxw2GsUDBWjCU4Bk3H4yOVaiSwBoWTFrJsEzILEbk9 bWhrfUXbbTarEdwfNKzh8Ymq3lJqvVMHoi3zE', Version: 1.1, Content: , Headers: { Accept: text/event-stream }
      Mar-17 5:37:35 PM
      Starting Plug-In
      Plugin Nest started successfully in 221 milliseconds
      Mar-17 5:37:35 PM
      Nest
      INFO Nest version 3.0.0.31
      Mar-17 5:37:35 PM
      Starting Plug-In
      Initializing plugin Nest ...
      Mar-17 5:37:35 PM
      Info
      Plugin Nest has connected. IP:127.0.0.1:xxxx
      Steve
        Somehow your system is using an old NestSharp.dll.
        Reinstall the plugin from the updater, and make sure there isn't a NestSharp.dll in your Homeseer app folder, this dll should only be in bin/Nest
          Spud,
          Thanks. Do I need to delete Pi first before re install?
          Cheers
          Steve
            Originally posted by Stevieboy View Post
            Spud,
            Cheers
            no, but if you manually copied the files in the homeseer dir, you need to delete them.
              Spud,
              Thanks, that did the trick. Need it as its currently snowing this side of the pond!
              Thanks for prompt response.
              Steve
              Steve
                Hi Spud,
                Short lived I'm afraid. Adjusted temp on device page and now it appears to have stopped again. Will post log shortly.
                Cheers
                Log below. I can confirm that the.dll file is in bin/nest and no copy located in the HS app.
                Mar-18 3:07:08 PM
                Nest
                DEBUG event: keep-alive
                Mar-18 3:06:38 PM
                Nest
                DEBUG data: null
                Mar-18 3:06:38 PM
                Nest
                Mar-18 3:06:08 PM
                Nest
                DEBUG data: null
                Mar-18 3:06:08 PM
                Nest
                Mar-18 3:05:41 PM
                Nest
                Mar-18 3:05:39 PM
                Nest
                DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"DCAZxmy1g568pg3zuoxnBQ_ VumSUMP-v":{"humidity":25,"locale":"en-GB","temperature_scale":"C","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.6.6-4","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiMtjQbZC oA_a89rhPAjLBKgj6J6fiZirIA","device_id":"DCAZxmy1g568pg3zuox nBQ_VumSUMP-v","name":"Lounge","can_heat":true,"can_cool":false,"target_ temperature_c":22.0,"target_temperature_f":72,"target_temper ature_high_c":24.0,"target_temperature_high_f":75,"target_te mperature_low_c":20.0,"target_temperature_low_f":68,"ambient _temperature_c":21.5,"ambient_temperature_f":71,"away_temper ature_high_c":24.0,"away_temperature_high_f":76,"away_temper ature_low_c":17.0,"away_temperature_low_f":63,"eco_temperatu re_high_c":24.0,"eco_temperature_high_f":76,"eco_temperature _low_c":17.0,"eco_temperature_low_f":63,"is_locked":false,"l ocked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_temp_m ax_c":22.0,"locked_temp_max_f":72,"sunlight_correction_activ e":false,"sunlight_correction_enabled":true,"structure_id":" dU3b7uEF7KsIS-zAeU9a6AzOkTKtjFaBvv-IS4IqQpaucRiNaZgCoQ","fan_timer_active":false,"fan_timer_tim eout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~65","time_to_tar get_training":"ready","where_name":"Lounge","label":"","name _long":"Lounge Thermostat","is_online":true,"last_connection":"2018-03-18T14:47:40.155Z","hvac_state":"heating"}}},"structures":{"d U3b7uEF7KsIS-zAeU9a6AzOkTKtjFaBvv-IS4IqQpaucRiNaZgCoQ":{"name":"Sandalwood","country_code":"GB ","time_zone":"Europe/London","away":"home","thermostats":["DCAZxmy1g568pg3zuoxnBQ_VumSUMP-v"],"structure_id":"dU3b7uEF7KsIS-zAeU9a6AzOkTKtjFaBvv-IS4IqQpaucRiNaZgCoQ","wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGe MA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTH qQGf0TJGeMA","name":"Driveway"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTEmTjvca91Q9A":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q9A","name":"Upstairs"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGEY2KDrCGVSQ":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGEY2KDrCGVS Q","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTEQbYDGG26IUQ":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26IUQ","name":"Backyard"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHDWahECEab0A":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHDWahECEa b0A","name":"Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTEB5E9EV7d93w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTEB5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFcdiDipAgT DA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF cdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdS i_g":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT FsTZUOmdSi_g","name":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7 nvpeg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTESyIBY7nvpeg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3M QnKhHOEzrxhFivj_GTHBlgeGDkyHZA":{"where_id":"e4FzI0k3ounJK98 jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGDkyHZA","name":"Office"},"e 4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA":{"whe re_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRs rA","name":"Den"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TGh8lvkqT2xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEz rxhFivj_GTGh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7Yy OQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF mAHn8c7YyOQ","name":"Outside"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4F zI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw":{"where _id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw ","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiMtjQbZCoA_a89rhPAj LBKgj6J6fiZirIA":{"where_id":"e4FzI0k3ounJK98jBApsiMtjQbZCoA _a89rhPAjLBKgj6J6fiZirIA","name":"Lounge"}}}},"metadata":{"a ccess_token":"c.4GY9Qcl9Xe1XdNrKI8EUEdTmqsawPKZL4ccPKseR1feo vJzvgO8V04roCHT9qPKXGnxw2GsUDBWjCU4Bk3H4yOVaiSwBoWTFrJsEzILE bk9bWhrfUXbbTarEdwfNKzh8Ymq3lJqvVMHoi3zE","client_version":5 ,"user_id":"z.1.1.KVO0gW4Ld9/dhV/lBIw9/2FpGQK8i+nWnVWtvwnQ93M="}}}
                Mar-18 3:05:39 PM
                Nest
                DEBUG event: put
                Mar-18 3:05:39 PM
                Nest
                Mar-18 3:05:39 PM
                Nest
                Mar-18 3:05:39 PM
                Nest
                Mar-18 3:05:37 PM
                Nest
                Mar-18 3:05:36 PM
                Nest
                Mar-18 3:05:19 PM
                Nest
                INFO Shutting Down Nest plugin
                Mar-18 3:04:53 PM
                Nest
                DEBUG data: null
                Mar-18 3:04:53 PM
                Nest
                Mar-18 3:04:23 PM
                Nest
                DEBUG data: null
                Mar-18 3:04:23 PM
                Nest
                Mar-18 3:03:53 PM
                Nest
                DEBUG data: null
                Mar-18 3:03:53 PM
                Nest
                Mar-18 3:03:23 PM
                Nest
                DEBUG data: null
                Mar-18 3:03:23 PM
                Nest
                Mar-18 3:02:53 PM
                Nest
                DEBUG data: null
                Mar-18 3:02:53 PM
                Nest
                Mar-18 3:02:23 PM
                Nest
                DEBUG data: null
                Mar-18 3:02:23 PM
                Nest
                Mar-18 3:01:53 PM
                Nest
                DEBUG data: null
                Mar-18 3:01:53 PM
                Nest
                Mar-18 3:01:23 PM
                Nest
                DEBUG data: null
                Mar-18 3:01:23 PM
                Nest
                Mar-18 3:00:56 PM
                Nest
                DEBUG instance: 4d687ab5-0f65-411a-a162-9fb1e807e82c
                Mar-18 3:00:56 PM
                Nest
                DEBUG message: blocked
                Mar-18 3:00:56 PM
                Nest
                DEBUG type: https://developer.nest.com/documenta...ssages#blocked
                Mar-18 3:00:56 PM
                Nest
                DEBUG error: blocked
                Mar-18 3:00:56 PM
                Nest
                ERROR blocked
                Mar-18 3:00:56 PM
                Nest
                DEBUG PUT: path=devices/thermostats/DCAZxmy1g568pg3zuoxnBQ_VumSUMP-v payload={"target_temperature_c":21.5}
                Mar-18 3:00:56 PM
                Nest
                DEBUG instance: 249eed42-63fa-424a-b930-72968a12e205
                Mar-18 3:00:56 PM
                Nest
                Mar-18 3:00:56 PM
                Nest
                Mar-18 3:00:56 PM
                Nest
                Mar-18 3:00:56 PM
                Nest
                ERROR blocked
                Mar-18 3:00:55 PM
                Nest
                Mar-18 3:00:53 PM
                Nest
                DEBUG data: null
                Mar-18 3:00:53 PM
                Nest
                Mar-18 3:00:44 PM
                Nest
                DEBUG instance: a578a95b-29cc-40df-8cbf-16cebb00f4a8
                Mar-18 3:00:44 PM
                Nest
                Mar-18 3:00:44 PM
                Nest
                Mar-18 3:00:44 PM
                Nest
                Mar-18 3:00:44 PM
                Nest
                ERROR blocked
                Mar-18 3:00:43 PM
                Nest
                Mar-18 3:00:23 PM
                Nest
                DEBUG data: null
                Mar-18 3:00:23 PM
                Nest
                Mar-18 2:59:53 PM
                Nest
                DEBUG data: null
                Mar-18 2:59:53 PM
                Nest
                Mar-18 2:59:23 PM
                Nest
                DEBUG data: null
                Mar-18 2:59:23 PM
                Nest
                Mar-18 2:58:53 PM
                Nest
                DEBUG data: null
                Mar-18 2:58:53 PM
                Nest
                Mar-18 2:58:23 PM
                Nest
                DEBUG data: null
                Mar-18 2:58:23 PM
                Nest
                Mar-18 2:57:53 PM
                Nest
                DEBUG data: null
                Mar-18 2:57:53 PM
                Nest
                Mar-18 2:57:23 PM
                Nest
                DEBUG data: null
                Mar-18 2:57:23 PM
                Nest
                Mar-18 2:56:53 PM
                Nest
                DEBUG data: null
                Mar-18 2:56:53 PM
                Nest
                Mar-18 2:56:23 PM
                Nest
                DEBUG data: null
                Mar-18 2:56:23 PM
                Nest
                Mar-18 2:55:53 PM
                Nest
                DEBUG data: null
                Mar-18 2:55:53 PM
                Nest
                Mar-18 2:55:23 PM
                Nest
                DEBUG data: null
                Mar-18 2:55:23 PM
                Nest
                Mar-18 2:54:53 PM
                Nest
                DEBUG data: null
                Mar-18 2:54:53 PM
                Nest
                Mar-18 2:54:23 PM
                Nest
                DEBUG data: null
                Mar-18 2:54:23 PM
                Nest
                Mar-18 2:53:55 PM
                Nest
                Mar-18 2:53:53 PM
                Nest
                Mar-18 2:53:53 PM
                Nest
                DEBUG event: put
                Mar-18 2:53:53 PM
                Nest
                Mar-18 2:53:53 PM
                Nest
                Mar-18 2:53:53 PM
                Nest
                Mar-18 2:53:52 PM
                Nest
                Mar-18 2:53:50 PM
                Nest
                Mar-18 2:53:41 PM
                Nest
                Mar-18 2:53:16 PM
                Nest
                DEBUG data: null
                Mar-18 2:53:16 PM
                Nest
                Mar-18 2:52:46 PM
                Nest
                DEBUG data: null
                Mar-18 2:52:46 PM
                Nest
                Mar-18 2:52:18 PM
                Nest
                Mar-18 2:52:16 PM
                Nest
                Mar-18 2:52:16 PM
                Nest
                DEBUG event: put
                Mar-18 2:52:16 PM
                Nest
                Mar-18 2:52:16 PM
                Nest
                Mar-18 2:52:16 PM
                Nest
                Mar-18 2:52:15 PM
                Nest
                Mar-18 2:52:13 PM
                Nest
                Mar-18 2:52:03 PM
                Nest
                101 log entries, displaying entries from 0
                Steve
                  Nest
                  Mar-18 3:00:56 PM
                  Nest
                  Mar-18 3:00:56 PM
                  Nest
                  Mar-18 3:00:56 PM
                  Nest
                  ERROR blocked
                  Mar-18 3:00:56 PM
                  as explained here, this error means you have reach the "rate limit" imposed by Nest. This usually happen when you test the plugin and issue too many requests.
                  you just need to wait 1 day or 2 until you are allowed again to do some requests.
                  note that this problem does not prevent the devices to be updated with correct values, it just prevent you from doing any action from HS.
                    Thanks Spud, that makes sense
                    Cheers
                    Sent from my iPhone using Tapatalk Pro
                    Steve
                      I am having the same issue as the original poster. Noticed this morning that my devices are not updating but commands are being send to Nest. So I rebooted, nothing, then I updated the plugin, still nothing. I checked the .dll mentioned below and it appears to be in the correct place.
                      Log file is attached.
                      I see that it has blocked me because I issued too many commands but hopefully you can see something from the log that would help solve this?
                      Thanks.
                        I am also having issues controlling my thermostat from Homeseer since the last update.
                        Getting this in the log:
                        Mar-21 09:50:06 Nest ERROR Unexpected character encountered while parsing value: <. Path '', line 0, position 0.
                        Mar-21 09:50:03 Occupancy 0,
                        Mar-21 09:50:03 Device Control Device: Downstairs HVAC Mode to Eco (4)
                        I am on 3.0.0.31.
                          Thanks.
                          there is nothing to see in your logs, if you get the "blocked" error you just need to wait to be unblocked.
                            I am on 3.0.0.31.
                            It looks like a different problem, Can you set the log level to debug and capture the logs again.
                            thanks
                              thanks
                              After reboot, seems to have started working again... Sorry for the bother.
