Nest Plugin generates bogus homeseer triggers
  • Nest Plugin generates bogus homeseer triggers
    This post is directed to the author of the homeseer Nest Plugin.
    I have encountered a problem with the Nest Plugin where iit is generating bogus triggers for non-events that do not occur.
    This occurs for all my Nest Thermostats.
    I have generated a simple example that shows this.
    The example consist of four events,
    1. An event to manually trigger to set the living room thermostat to off.
    2. An event to manually trigger to set the living room thermostat to heat-cool
    3. An event to trigger when the living room thermostat target high changes and speaks a message.
    4. An event to trigger when the living room thermostat target low changes and speaks a message.
    If I manually trigger event 1, even 3 and event 4 trigger even though the living room target high and low temperatures have not been modified.
    Also the living room thermostat target high and low both change to 68 even though all I have done is set the HVAC_Mode to Off!!!
    Here is a log of what happens:
    Jul-27 4:06:42 PM TTS Speak ():Living Room Target Temperature High has changed!!!
    Jul-27 4:06:42 PM Event Event Trigger "Living Room Living Room Thermostat Event 3" <<This should not happen
    Jul-27 4:06:42 PM TTS Speak ():Living Room Target Temperature Low has changed!!!
    Jul-27 4:06:42 PM Event Event Trigger "Living Room Living Room Thermostat Event 4" <<This should not happen
    Jul-27 4:06:42 PM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6Ggpfjpnh8S tJw_ VumSUMP-v":{"humidity":50,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":fals e, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"8sVQstDpoqzxsCbUHChuimqhE q49 GR8-4pU0g2Z6cO6fn6ueU4z2Uw","device_id":"gi6tL1If6Ggpfjpnh8StJw_ VumSUMP-v","name":"Guest Bedroom","can_heat":true,"can_cool":true,"target_temperature _c":20.0,"target_temperature_f":68,"target_temperature_hig h_ c":23.0,"target_temperature_high_f":74,"target_temperatur e_l ow_c":16.5,"target_temperature_low_f":62,"ambient_temperatur e_c":21.5,"ambient_temperature_f":72,"away_temperature_high _ c":26.5,"away_temperature_high_f":80,"away_temperature_lo w_c ":15.5,"away_temperature_low_f":60,"eco_temperature_high _c": 26.5,"eco_temperature_high_f":80,"eco_temperature_low_c":15. 5,"eco_temperature_low_f":60,"is_locked":false,"locked_tem p_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":fals e,"s unlight_correction_enabled":true,"structure_id":"mFmWr7Kx37x Jd368X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A","fan_timer_active":false,"fan_timer_tim eout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat-cool","time_to_target":"~0","time_to_target_training":"ready ","where_name":"Guest Bedroom","label":"","name_long":"Guest Bedroom Thermostat","is_online":true,"last_connection":"2018-07-27T23:01:46.048Z","hvac_state":"off"},"gi6tL1If6Gj7UgXpOqoGa Q_VumSUMP-v":{"humidity":55,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":fals e, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKh HOEzrxhFivj_GTGp8x7lb5eAZA","device_id":"gi6tL1If6Gj7UgXpOqo GaQ_VumSUMP-v","name":"Master Bedroom","can_heat":true,"can_cool":true,"target_temperature _c":20.0,"target_temperature_f":68,"target_temperature_hig h_ c":24.5,"target_temperature_high_f":76,"target_temperatur e_l ow_c":18.5,"target_temperature_low_f":65,"ambient_temperatur e_c":23.5,"ambient_temperature_f":75,"away_temperature_high _ c":29.0,"away_temperature_high_f":85,"away_temperature_lo w_c ":15.5,"away_temperature_low_f":60,"eco_temperature_high _c": 29.0,"eco_temperature_high_f":85,"eco_temperature_low_c":15. 5,"eco_temperature_low_f":60,"is_locked":false,"locked_tem p_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":fals e,"s unlight_correction_enabled":true,"structure_id":"mFmWr7Kx37x Jd368X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A","fan_timer_active":false,"fan_timer_tim eout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat-cool","time_to_target":"~0","time_to_target_training":"ready ","where_name":"Master Bedroom","label":"","name_long":"Master Bedroom Thermostat","is_online":true,"last_connection":"2018-07-27T23:02:17.832Z","hvac_state":"off"},"gi6tL1If6GiqipsmP9PBZ Q_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":fals e, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKh HOEzrxhFivj_GTGEY2KDrCGVSQ","device_id":"gi6tL1If6GiqipsmP9P BZQ_VumSUMP-v","name":"Family Room","can_heat":true,"can_cool":true,"target_temperature_c" :20.0,"target_temperature_f":68,"target_temperature_high_c": 24.5,"target_temperature_high_f":76,"target_temperature_low_ c":16.5,"target_temperature_low_f":62,"ambient_temperatur e_c ":24.5,"ambient_temperature_f":77,"away_temperature_high _c": 29.0,"away_temperature_high_f":85,"away_temperature_low_c":1 2.5,"away_temperature_low_f":55,"eco_temperature_high_c":29. 0,"eco_temperature_high_f":85,"eco_temperature_low_c":12.5 ," eco_temperature_low_f":55,"is_locked":false,"locked_temp_min _c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," lo cked_temp_max_f":72,"sunlight_correction_active":false,"sunl ight_correction_enabled":true,"structure_id":"mFmWr7Kx37xJd3 68X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A","fan_timer_active":false,"fan_timer_tim eout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat-cool","time_to_target":"~0","time_to_target_training":"ready ","where_name":"Family Room","label":"","name_long":"Family Room Thermostat","is_online":true,"last_connection":"2018-07-27T23:04:38.165Z","hvac_state":"off"},"gi6tL1If6GjDqiBH-kLguQ_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":fals e, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"XU6YTHfEhR34Idh_OiZypVDRA Os0 LiGpeTzKv_oSzLzpd7_cNra7og","device_id":"gi6tL1If6GjDqiBH-kLguQ_VumSUMP-v","name":"Computer Room","can_heat":true,"can_cool":true,"target_temperature_c" :20.0,"target_temperature_f":68,"target_temperature_high_c": 24.5,"target_temperature_high_f":76,"target_temperature_low_ c":18.5,"target_temperature_low_f":65,"ambient_temperatur e_c ":24.5,"ambient_temperature_f":77,"away_temperature_high _c": 26.5,"away_temperature_high_f":80,"away_temperature_low_c":1 5.5,"away_temperature_low_f":60,"eco_temperature_high_c":26. 5,"eco_temperature_high_f":80,"eco_temperature_low_c":15.5 ," eco_temperature_low_f":60,"is_locked":false,"locked_temp_min _c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," lo cked_temp_max_f":72,"sunlight_correction_active":false,"sunl ight_correction_enabled":true,"structure_id":"mFmWr7Kx37xJd3 68X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A","fan_timer_active":true,"fan_timer_time out":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat-cool","time_to_target":"~0","time_to_target_training":"ready ","where_name":"Computer Room","label":"","name_long":"Computer Room Thermostat","is_online":true,"last_connection":"2018-07-27T23:01:48.611Z","hvac_state":"cooling"},"gi6tL1If6GgI5lz3C N2otA_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":fals e, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKh HOEzrxhFivj_GTGqA1DwGeRj6A","device_id":"gi6tL1If6GgI5lz3CN2 otA_VumSUMP-v","name":"Living Room","can_heat":true,"can_cool":true,"target_temperature_c" :20.0,"target_temperature_f":68,"target_temperature_high_c": 24.5,"target_temperature_high_f":76,"target_temperature_low_ c":18.5,"target_temperature_low_f":65,"ambient_temperatur e_c ":24.0,"ambient_temperature_f":76,"away_temperature_high _c": 29.0,"away_temperature_high_f":85,"away_temperature_low_c":1 8.0,"away_temperature_low_f":65,"eco_temperature_high_c":29. 0,"eco_temperature_high_f":85,"eco_temperature_low_c":18.0 ," eco_temperature_low_f":65,"is_locked":false,"locked_temp_min _c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," lo cked_temp_max_f":72,"sunlight_correction_active":false,"sunl ight_correction_enabled":true,"structure_id":"mFmWr7Kx37xJd3 68X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A","fan_timer_active":false,"fan_timer_tim eout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"off","time_to_target":"~0","time_to_ta rge t_training":"ready","where_name":"Living Room","label":"","name_long":"Living Room Thermostat","is_online":true,"last_connection":"2018-07-27T23:04:40.970Z","hvac_state":"off"}}},"structures":{"mFmWr 7Kx37xJd368X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A":{"name":"Buck Residence","country_code":"US","time_zone":"America/Los_Angeles","away":"home","thermostats":["gi6tL1If6Ggpfjpnh8StJw_VumSUMP-v","gi6tL1If6GgI5lz3CN2otA_VumSUMP-v","gi6tL1If6GiqipsmP9PBZQ_VumSUMP-v","gi6tL1If6Gj7UgXpOqoGaQ_VumSUMP-v","gi6tL1If6GjDqiBH-kLguQ_VumSUMP-v"],"structure_id":"mFmWr7Kx37xJd368X9QCyS_eAQN1bEs9rh-EKkb4d9zwqOo7y6wp4A","wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTEQbYDGG26IUQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTEQbYDGG26IUQ","name":"Backyard"},"e4F zI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw":{"where _id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqy w ","name":"Basement"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFiv j_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI 0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"D en"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi _g ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFsT ZUOmdSi_g","name":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx h Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFcdiDipAgT DA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TF cdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G T Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TG goDbPcAiiOw","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q9A":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q9 A","name":"Upstairs"},"XU6YTHfEhR34Idh_OiZypVDRAOs0LiGpeT zKv _oSzLzpd7_cNra7og":{"where_id":"XU6YTHfEhR34Idh_OiZypVDRAOs0 LiGpeTzKv_oSzLzpd7_cNra7og","name":"Computer Room"},"8sVQstDpoqzxsCbUHChuimqhEq49GR8-4pU0g2Z6cO6fn6ueU4z2Uw":{"where_id":"8sVQstDpoqzxsCbUHChuimq hEq49GR8-4pU0g2Z6cO6fn6ueU4z2Uw","name":"Guest Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcE YA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TE tu3v5WLcEYA","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTEZUqMqRwg9hA":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9hA","name":"Deck"},"e4FzI0 k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqFCpQxg":{"where_id ":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqFCpQx g"," name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTHmMVMfIExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":" Side Door"}}}},"metadata":{"access_token":"c.YpM9ruFgTPhUyzJOoH3B pKDEBI9MDqJooTZTSvIBzrQ4JSOEchVT72bnuTMxdVrfNahYencOkkkwbYyn DzAaoe1yP342FKyhUwPHeHDi4WLZYF7EdmwMXG63aa3xuM9NvDjMqWLGCbmR uKLd","client_version":5,"user_id":"z.1.1.kwAQ9DMndSmRktvxYF ctWuNybR+FJn69Hrzybunmlas="}}}
    Jul-27 4:06:42 PM Nest DEBUG event: put
    Jul-27 4:06:38 PM Nest DEBUG PUT: path=devices/thermostats/gi6tL1If6GgI5lz3CN2otA_VumSUMP-v payload={"hvac_mode":"off"}
    Jul-27 4:06:38 PM Device Control Device: Floor 1 Living Room HVAC Mode to Off (0)
    Jul-27 4:06:38 PM Event Event Trigger "Living Room Living Room Thermostat Event 1"
    Jul-27 4:06:38 PM Event Event Living Room Living Room Thermostat Event 1 triggered by the event page 'Run' button.
    Jul-27 4:06:36 PM Nest DEBUG data: null
    Jul-27 4:06:36 PM Nest DEBUG event: keep-alive
    I really need this fixed since these bogus events are messing up my homeseer program. Also I think this is not the only bogus events being generated.
    The events are really simple for generating this problem and I have uploaded them. Also I have the web display showing the thermostat target high and low values changed to 68 even though no event changed them!!!
    -Gary Buck
    Here is my system information:
    MESSAGE BOARD (copy/paste section below to message board posts)
    Current Date/Time: 7/27/2018 7:00:27 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.435
    System Uptime: 0 Days 5 Hours 48 Minutes 19 Seconds
    IP Address: 192.168.7.50
    Number of Devices: 600
    Number of Events: 276
    Available Threads: 400
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed: Windows Defender McAfee VirusScan
    Enabled Plug-Ins
    3.0.0.14: Applied Digital Ocelot
    2.18.1.2: MCSSPRINKLERSP
    3.0.2.0: Napco Gemini
    3.0.0.31: Nest
    3.0.0.43: UPBSpud
    3.0.0.21: VWS
    HELP DESK (copy/paste section below to help desk tickets & emails)
    Current Date/Time: 7/27/2018 7:00:28 PM
    System Uptime: 0 Days 5 Hours 48 Minutes 20 Seconds
    Event Threads: 0
    Email Send Queue: 0
    License: Registered
    License: 115538
    User Name and Access Level: gbuck41108 (Admin)
    WAN IP Address: 184.21.208.6
    Web Server Port: 80
    Location: (Latitude) 44.93 (Longitude) -123.03 City/State-US-Oregon,Salem,-123.03,44.93
    Enabled Plug-Ins
    3.0.0.31: Nest
    3.0.0.43: UPBSpud
    3.0.0.21: VWS
    Just realized these bogus triggers are occurring at the rate of about one per second even when nothing is changing in the Nest thermostat, the plugin is generating them. You do not have to change the HVAC_mode...
      The problem is the use of the trigger "...changes and become Any Value". This trigger will fire everytime the device value is set by the plugin even if the value has not changed. I know it's misleading, but it's a HomeSeer Event Engine problem, not a problem with the Nest plugin.
