Nest with 2 Homes
    Nest with 2 Homes
    I have 2 homes, both with a Homeseer hub and Nest thermostats at each. Nest supports both homes, so that is fine. The issue is that the Homeseer plugin seems to pull "all" information into both homes. So, I see the stats from home "A" in the homseseer devices in home "B".
    How about adding a feature into the plugin that will allow you to determine which stats or which home to integrate with?
    I know I can setup each home on a separate NEST account, but that is a pain-in-the-^%$ solution since logging out of the app and re-logging in to the other login isn't very functional.
    Help?
    I guess I could add some kind of filter, but can't you just hide the devices you don't want to see from the "device management" page?
      Interesting. I had tried "deleting" them, but they keep coming back. Hadn't considered "hiding" them... will give it a go!
