Random Error in Nest Plugin
  • Random Error in Nest Plugin
    Spud,
    Any Idea what this could be ? only happens once every 45 mins or so. I notice that the event that is linked to adjusting thermostats does not pass it on to Nest
    Thanks in advance !!!
    Nov-03 9:47:12 AM Nest DEBUG event: keep-alive
    Nov-03 9:47:12 AM Nest DEBUG data: null
    Nov-03 9:46:40 AM Nest DEBUG event: keep-alive
    Nov-03 9:46:40 AM Nest DEBUG data: null
    Nov-03 9:46:10 AM Nest DEBUG event: keep-alive
    Nov-03 9:46:10 AM Nest DEBUG data: null
    Nov-03 9:45:40 AM Nest DEBUG data: null
    Nov-03 9:45:40 AM Nest DEBUG event: keep-alive
    Nov-03 9:45:11 AM Nest DEBUG event: keep-alive
    Nov-03 9:45:11 AM Nest DEBUG data: null
    Nov-03 9:44:36 AM Nest DEBUG event: keep-alive
    Nov-03 9:44:36 AM Nest DEBUG data: null
    Nov-03 9:44:22 AM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GiebP7dxtk_gA_ VumSUMP-v":{"humidity":55,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"gi6tL1If6GiebP7dxtk_gA_Vu mSUMP-v","name":"Second Floor (Matts Bedroom)","can_heat":true,"can_cool":false,"target_temperatu re_c":21.0,"target_temperature_f":70,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":21.0,"ambient_temperature_f":71,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":4.0,"away_temperature_low_f":40,"eco_temperature_high_c" :24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":4. 0,"eco_temperature_low_f":40,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"dLgC7sfKoPr J3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"off","time_to_target":"~0","time_to_targe t_training":"ready","where_name":"Second Floor","label":"Matts Bedroom","name_long":"Second Floor Thermostat (Matts Bedroom)","is_online":true,"last_connection":"2018-11-03T13:44:18.179Z","hvac_state":"off"},"gi6tL1If6GimWiK3RdWU2 A_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"gi6tL1If6GimWiK3RdWU 2A_VumSUMP-v","name":"Basement (Family Room)","can_heat":true,"can_cool":false,"target_temperature_ c":18.5,"target_temperature_f":66,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":73,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"off","time_to_target":"~0","time_to_targe t_training":"ready","where_name":"Basement","label":"Family Room","name_long":"Basement Thermostat (Family Room)","is_online":true,"last_connection":"2018-11-03T13:42:59.541Z","hvac_state":"off"},"gi6tL1If6Gie47mRVAZnV g_VumSUMP-v":{"humidity":50,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.8.2-1","has_leaf":true,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFz pHB0smQIReozGe2_xR325zDmw","device_id":"gi6tL1If6Gie47mRVAZn Vg_VumSUMP-v","name":"First Floor (Hallway)","can_heat":true,"can_cool":true,"target_temperatu re_c":20.5,"target_temperature_f":69,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":20.5,"ambient_temperature_f":69,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c ":24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":2 1.0,"eco_temperature_low_f":70,"is_locked":false,"locked_tem p_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22. 0,"locked_temp_max_f":72,"sunlight_correction_active":false, "sunlight_correction_enabled":true,"structure_id":"dLgC7sfKo PrJ3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_ac tive":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"off","time_to_target":"~0","time_to_targe t_training":"ready","where_name":"First Floor","label":"Hallway","name_long":"First Floor Thermostat (Hallway)","is_online":true,"last_connection":"2018-11-03T13:42:59.476Z","hvac_state":"off"},"S96TwpES2meBqMKz_Znwx w_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFz pHB0smQIReozGe2_xR325zDmw","device_id":"S96TwpES2meBqMKz_Znw xw_VumSUMP-v","name":"First Floor (Dining Room)","can_heat":true,"can_cool":false,"target_temperature_ c":21.0,"target_temperature_f":70,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":74,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"off","time_to_target":"~0","time_to_targe t_training":"ready","where_name":"First Floor","label":"Dining Room","name_long":"First Floor Thermostat (Dining Room)","is_online":true,"last_connection":"2018-11-03T13:42:58.674Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbIaG96_52eMvA_VumSUMP-v":{"name":"Basement (Laundry and Boiler Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Laundry and Boiler Room)","is_online":true,"last_connection":"2018-11-03T07:16:12.881Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v":{"name":"Basement (Office Area)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Office Area)","is_online":true,"last_connection":"2018-11-02T21:19:16.814Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v":{"name":"First Floor Hallway (Hallway and 1st Floor Bedrooms)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.3rc2","where_id":"bp 9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ","device_id":"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v","where_name":"First Floor Hallway","name_long":"First Floor Hallway Nest Protect (Hallway and 1st Floor Bedrooms)","is_online":true,"last_connection":"2018-11-02T21:19:16.561Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false},"cw2LlF6qsbJ6blV1w9asew_VumSUMP-v":{"name":"Second Floor (Bryans Bedroom)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"cw2LlF6qsbJ6blV1w9asew_Vu mSUMP-v","where_name":"Second Floor","name_long":"Second Floor Nest Protect (Bryans Bedroom)","is_online":true,"last_connection":"2018-11-02T21:18:15.781Z","battery_health":"ok
    My Config is as follows
    Current Date/Time: 11/3/2018 9:44:00 AM
    HomeSeer Version: HS3 Pro Edition 3.0.0.435
    Operating System: Microsoft Windows Server 2012 R2 Standard - Server
    System Uptime: 0 Days 1 Hour 50 Minutes 5 Seconds
    IP Address: 10.0.1.8
    Number of Devices: 338
    Number of Events: 71
    Available Threads: 400
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed:
    Enabled Plug-Ins
    3.0.19.0: BLLock
    1.3.4.3: Device History
    3.0.0.51: EasyTrigger
    3.0.2.1: Napco Gemini
    3.0.0.31: Nest
    2.0.0.0: SNMPMONITOR
    3.0.0.88: weatherXML
    3.0.0.36: X10
    3.0.1.244: Z-Wave
    Error below
    Nov-03 9:32:41 AM Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult) at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult) at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.
    d__8.MoveNext() --- End of inner exception stack trace --- at System.AggregateException.Handle(Func`2 predicate) at NestSharp.NestClient.SetData(String path, String payload) at NestSharp.NestClient.SetHVACMode(String thermostatId, String mode) at HSPI_Nest.NestApp.SetControlValue(Int32 dvref, Double value) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult) at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult) at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace --- at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.
    d__8.MoveNext()<---
    Nov-03 9:32:41 AM Nest ERROR One or more errors occurred.
    so the error only happen when your event run?
    Could you post the full debug logs, so that I can see the request that is sent.
    thanks
      Note Did a reboot and it has not occurred since
      but here are the logs
      Nov-03 7:28:06 PM Nest DEBUG data: null
      Nov-03 7:27:54 PM Nest DEBUG event: put
      Nov-03 7:27:54 PM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GiebP7dxtk_gA_ VumSUMP-v":{"humidity":55,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"gi6tL1If6GiebP7dxtk_gA_Vu mSUMP-v","name":"Second Floor (Matts Bedroom)","can_heat":true,"can_cool":false,"target_temperatu re_c":21.0,"target_temperature_f":70,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":22.0,"ambient_temperature_f":72,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":4.0,"away_temperature_low_f":40,"eco_temperature_high_c" :24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":4. 0,"eco_temperature_low_f":40,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"dLgC7sfKoPr J3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Second Floor","label":"Matts Bedroom","name_long":"Second Floor Thermostat (Matts Bedroom)","is_online":true,"last_connection":"2018-11-03T23:21:32.629Z","hvac_state":"off"},"gi6tL1If6GimWiK3RdWU2 A_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"gi6tL1If6GimWiK3RdWU 2A_VumSUMP-v","name":"Basement (Family Room)","can_heat":true,"can_cool":false,"target_temperature_ c":18.5,"target_temperature_f":66,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":22.5,"ambient_temperature_f":73,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"Family Room","name_long":"Basement Thermostat (Family Room)","is_online":true,"last_connection":"2018-11-03T23:27:54.793Z","hvac_state":"off"},"gi6tL1If6Gie47mRVAZnV g_VumSUMP-v":{"humidity":45,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"gi6tL1If6Gie47mRVAZ nVg_VumSUMP-v","name":"First Floor (Hallway)","can_heat":true,"can_cool":true,"target_temperatu re_c":20.5,"target_temperature_f":69,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":20.0,"ambient_temperature_f":69,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c ":24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":2 1.0,"eco_temperature_low_f":70,"is_locked":false,"locked_tem p_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22. 0,"locked_temp_max_f":72,"sunlight_correction_active":false, "sunlight_correction_enabled":true,"structure_id":"dLgC7sfKo PrJ3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_ac tive":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Hallway","name_long":"First Floor Thermostat (Hallway)","is_online":true,"last_connection":"2018-11-03T23:25:46.398Z","hvac_state":"off"},"S96TwpES2meBqMKz_Znwx w_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"S96TwpES2meBqMKz_Zn wxw_VumSUMP-v","name":"First Floor (Dining Room)","can_heat":true,"can_cool":false,"target_temperature_ c":21.0,"target_temperature_f":70,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":74,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Dining Room","name_long":"First Floor Thermostat (Dining Room)","is_online":true,"last_connection":"2018-11-03T23:25:45.969Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbIaG96_52eMvA_VumSUMP-v":{"name":"Basement (Laundry and Boiler Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Laundry and Boiler Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.923Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v":{"name":"Basement (Office Area)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Office Area)","is_online":true,"last_connection":"2018-11-03T21:19:57.095Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v":{"name":"First Floor Hallway (Hallway and 1st Floor Bedrooms)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"bp 9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ","device_id":"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v","where_name":"First Floor Hallway","name_long":"First Floor Hallway Nest Protect (Hallway and 1st Floor Bedrooms)","is_online":true,"last_connection":"2018-11-03T21:19:56.860Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false},"cw2LlF6qsbJ6blV1w9asew_VumSUMP-v":{"name":"Second Floor (Bryans Bedroom)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"cw2LlF6qsbJ6blV1w9asew_Vu mSUMP-v","where_name":"Second Floor","name_long":"Second Floor Nest Protect (Bryans Bedroom)","is_online":true,"last_connection":"2018-11-03T21:19:56.952Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v":{"name":"First Floor (Kitchen and Dining Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"u8 FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zDmw","devic e_id":"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","where_name":"First Floor","name_long":"First Floor Nest Protect (Kitchen and Dining Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.972Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:21.000Z"}}},"structures":{"dLgC7sfKoPrJ3j_umj8vLy0z gpMXNmLfU66XypSmQzeWWm2Jhvv75g":{"smoke_co_alarms":["cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","cw2LlF6qsbJ6blV1w9asew_VumSUMP-v","cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v"],"name":"Sweetie 51","country_code":"US","time_zone":"America/New_York","away":"home","thermostats":["gi6tL1If6GiebP7dxtk_gA_VumSUMP-v","gi6tL1If6Gie47mRVAZnVg_VumSUMP-v","gi6tL1If6GimWiK3RdWU2A_VumSUMP-v","S96TwpES2meBqMKz_Znwxw_VumSUMP-v"],"structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSmQze WWm2Jhvv75g","co_alarm_state":"ok","smoke_alarm_state":"ok", "wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK 98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ":{"where_id":"e4Fz I0k3ounJK98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ","name":" Bryan’s Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqR wg9hA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTEZUqMqRwg9hA","name":"Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"Den"},"e4FzI0k3 ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g":{"where_id": "e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","na me":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zD mw":{"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe 2_xR325zDmw","name":"First Floor"},"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA":{"where_id":"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA","name":"First Floor Dining Room"},"bp9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ":{"where_id":"bp9f8QEcqI6odJrlekOrbosohQBEGZF_V FQhPh9x_-Rbge88kLWanQ","name":"First Floor Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqF CpQxg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTGSJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTFcdiDipAgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"9iJ9Ni3dbnLgNWTTaoF17DIhfJag O3rvbxwQb5wCNlxBP9xFcRSdHw":{"where_id":"9iJ9Ni3dbnLgNWTTaoF 17DIhfJagO3rvbxwQb5wCNlxBP9xFcRSdHw","name":"Kitchen and Dining Room"},"EieUyv23YxRdcfOQEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw":{"where_id":"EieUyv23YxRdcfO QEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw","name":"Laundry Boiler Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj 6A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG qA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBTCTsFpxMSw rDEag":{"where_id":"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBT CTsFpxMSwrDEag","name":"Matts-Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA":{"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","name":"Second Floor"},"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2FhZE6lqzr2 8vw":{"where_id":"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2F hZE6lqzr28vw","name":"Second Floor Bryans Bedroom"},"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQl4xptz0dx yg7Pg":{"where_id":"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQ l4xptz0dxyg7Pg","name":"Second Floor Matt's Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHmMVMfI ExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":"Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"}}}},"metadata":{"access_token ":"c.ke2aKn4Lk468brOmNKH5VbdDconBThzoYlZn8yfmrf5zNzQPCnsFR79 ghvcx9QT7xr4MvjOINMi4yH4CNUDBw8QLVMd9rNI0ox518yZk7U6mH1qN3Q2 Lfo1nuKPYG9flbnG0Fdao6Mbo7bWL","client_version":5,"user_id": "z.1.1.qQrY0apShZDvWckwTv4cwPIalTd3gTx58uVTyVvk6Js="}}}
      Nov-03 7:27:54 PM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GiebP7dxtk_gA_ VumSUMP-v":{"humidity":55,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"gi6tL1If6GiebP7dxtk_gA_Vu mSUMP-v","name":"Second Floor (Matts Bedroom)","can_heat":true,"can_cool":false,"target_temperatu re_c":21.0,"target_temperature_f":70,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":22.0,"ambient_temperature_f":72,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":4.0,"away_temperature_low_f":40,"eco_temperature_high_c" :24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":4. 0,"eco_temperature_low_f":40,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"dLgC7sfKoPr J3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Second Floor","label":"Matts Bedroom","name_long":"Second Floor Thermostat (Matts Bedroom)","is_online":true,"last_connection":"2018-11-03T23:21:32.629Z","hvac_state":"off"},"gi6tL1If6GimWiK3RdWU2 A_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"gi6tL1If6GimWiK3RdWU 2A_VumSUMP-v","name":"Basement (Family Room)","can_heat":true,"can_cool":false,"target_temperature_ c":18.5,"target_temperature_f":66,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":21.5,"ambient_temperature_f":72,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"Family Room","name_long":"Basement Thermostat (Family Room)","is_online":true,"last_connection":"2018-11-03T23:27:54.793Z","hvac_state":"off"},"gi6tL1If6Gie47mRVAZnV g_VumSUMP-v":{"humidity":45,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"gi6tL1If6Gie47mRVAZ nVg_VumSUMP-v","name":"First Floor (Hallway)","can_heat":true,"can_cool":true,"target_temperatu re_c":20.5,"target_temperature_f":69,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":20.0,"ambient_temperature_f":69,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c ":24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":2 1.0,"eco_temperature_low_f":70,"is_locked":false,"locked_tem p_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22. 0,"locked_temp_max_f":72,"sunlight_correction_active":false, "sunlight_correction_enabled":true,"structure_id":"dLgC7sfKo PrJ3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_ac tive":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Hallway","name_long":"First Floor Thermostat (Hallway)","is_online":true,"last_connection":"2018-11-03T23:25:46.398Z","hvac_state":"off"},"S96TwpES2meBqMKz_Znwx w_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"S96TwpES2meBqMKz_Zn wxw_VumSUMP-v","name":"First Floor (Dining Room)","can_heat":true,"can_cool":false,"target_temperature_ c":21.0,"target_temperature_f":70,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":74,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Dining Room","name_long":"First Floor Thermostat (Dining Room)","is_online":true,"last_connection":"2018-11-03T23:25:45.969Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbIaG96_52eMvA_VumSUMP-v":{"name":"Basement (Laundry and Boiler Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Laundry and Boiler Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.923Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v":{"name":"Basement (Office Area)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Office Area)","is_online":true,"last_connection":"2018-11-03T21:19:57.095Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v":{"name":"First Floor Hallway (Hallway and 1st Floor Bedrooms)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"bp 9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ","device_id":"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v","where_name":"First Floor Hallway","name_long":"First Floor Hallway Nest Protect (Hallway and 1st Floor Bedrooms)","is_online":true,"last_connection":"2018-11-03T21:19:56.860Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false},"cw2LlF6qsbJ6blV1w9asew_VumSUMP-v":{"name":"Second Floor (Bryans Bedroom)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"cw2LlF6qsbJ6blV1w9asew_Vu mSUMP-v","where_name":"Second Floor","name_long":"Second Floor Nest Protect (Bryans Bedroom)","is_online":true,"last_connection":"2018-11-03T21:19:56.952Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v":{"name":"First Floor (Kitchen and Dining Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"u8 FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zDmw","devic e_id":"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","where_name":"First Floor","name_long":"First Floor Nest Protect (Kitchen and Dining Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.972Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:21.000Z"}}},"structures":{"dLgC7sfKoPrJ3j_umj8vLy0z gpMXNmLfU66XypSmQzeWWm2Jhvv75g":{"smoke_co_alarms":["cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","cw2LlF6qsbJ6blV1w9asew_VumSUMP-v","cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v"],"name":"Sweetie 51","country_code":"US","time_zone":"America/New_York","away":"home","thermostats":["gi6tL1If6GiebP7dxtk_gA_VumSUMP-v","gi6tL1If6Gie47mRVAZnVg_VumSUMP-v","gi6tL1If6GimWiK3RdWU2A_VumSUMP-v","S96TwpES2meBqMKz_Znwxw_VumSUMP-v"],"structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSmQze WWm2Jhvv75g","co_alarm_state":"ok","smoke_alarm_state":"ok", "wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK 98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ":{"where_id":"e4Fz I0k3ounJK98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ","name":" Bryan’s Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqR wg9hA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTEZUqMqRwg9hA","name":"Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"Den"},"e4FzI0k3 ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g":{"where_id": "e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","na me":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zD mw":{"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe 2_xR325zDmw","name":"First Floor"},"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA":{"where_id":"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA","name":"First Floor Dining Room"},"bp9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ":{"where_id":"bp9f8QEcqI6odJrlekOrbosohQBEGZF_V FQhPh9x_-Rbge88kLWanQ","name":"First Floor Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqF CpQxg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTGSJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTFcdiDipAgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"9iJ9Ni3dbnLgNWTTaoF17DIhfJag O3rvbxwQb5wCNlxBP9xFcRSdHw":{"where_id":"9iJ9Ni3dbnLgNWTTaoF 17DIhfJagO3rvbxwQb5wCNlxBP9xFcRSdHw","name":"Kitchen and Dining Room"},"EieUyv23YxRdcfOQEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw":{"where_id":"EieUyv23YxRdcfO QEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw","name":"Laundry Boiler Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj 6A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG qA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBTCTsFpxMSw rDEag":{"where_id":"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBT CTsFpxMSwrDEag","name":"Matts-Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA":{"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","name":"Second Floor"},"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2FhZE6lqzr2 8vw":{"where_id":"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2F hZE6lqzr28vw","name":"Second Floor Bryans Bedroom"},"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQl4xptz0dx yg7Pg":{"where_id":"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQ l4xptz0dxyg7Pg","name":"Second Floor Matt's Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHmMVMfI ExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":"Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"}}}},"metadata":{"access_token ":"c.ke2aKn4Lk468brOmNKH5VbdDconBThzoYlZn8yfmrf5zNzQPCnsFR79 ghvcx9QT7xr4MvjOINMi4yH4CNUDBw8QLVMd9rNI0ox518yZk7U6mH1qN3Q2 Lfo1nuKPYG9flbnG0Fdao6Mbo7bWL","client_version":5,"user_id": "z.1.1.qQrY0apShZDvWckwTv4cwPIalTd3gTx58uVTyVvk6Js="}}}
      Nov-03 7:27:36 PM Nest DEBUG event: keep-alive
      Nov-03 7:27:36 PM Nest DEBUG data: null
      Nov-03 7:27:06 PM Nest DEBUG event: keep-alive
      Nov-03 7:27:06 PM Nest DEBUG data: null
      Nov-03 7:26:36 PM Nest DEBUG event: keep-alive
      Nov-03 7:26:36 PM Nest DEBUG data: null
      Nov-03 7:26:06 PM Nest DEBUG event: keep-alive
      Nov-03 7:26:06 PM Nest DEBUG data: null
      Nov-03 7:25:46 PM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GiebP7dxtk_gA_ VumSUMP-v":{"humidity":55,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"gi6tL1If6GiebP7dxtk_gA_Vu mSUMP-v","name":"Second Floor (Matts Bedroom)","can_heat":true,"can_cool":false,"target_temperatu re_c":21.0,"target_temperature_f":70,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":22.0,"ambient_temperature_f":72,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":4.0,"away_temperature_low_f":40,"eco_temperature_high_c" :24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":4. 0,"eco_temperature_low_f":40,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"dLgC7sfKoPr J3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Second Floor","label":"Matts Bedroom","name_long":"Second Floor Thermostat (Matts Bedroom)","is_online":true,"last_connection":"2018-11-03T23:21:32.629Z","hvac_state":"off"},"gi6tL1If6GimWiK3RdWU2 A_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"gi6tL1If6GimWiK3RdWU 2A_VumSUMP-v","name":"Basement (Family Room)","can_heat":true,"can_cool":false,"target_temperature_ c":18.5,"target_temperature_f":66,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":21.5,"ambient_temperature_f":72,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"Family Room","name_long":"Basement Thermostat (Family Room)","is_online":true,"last_connection":"2018-11-03T23:21:31.220Z","hvac_state":"off"},"gi6tL1If6Gie47mRVAZnV g_VumSUMP-v":{"humidity":45,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"gi6tL1If6Gie47mRVAZ nVg_VumSUMP-v","name":"First Floor (Hallway)","can_heat":true,"can_cool":true,"target_temperatu re_c":20.5,"target_temperature_f":69,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":20.0,"ambient_temperature_f":69,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c ":24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":2 1.0,"eco_temperature_low_f":70,"is_locked":false,"locked_tem p_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22. 0,"locked_temp_max_f":72,"sunlight_correction_active":false, "sunlight_correction_enabled":true,"structure_id":"dLgC7sfKo PrJ3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_ac tive":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Hallway","name_long":"First Floor Thermostat (Hallway)","is_online":true,"last_connection":"2018-11-03T23:25:46.398Z","hvac_state":"off"},"S96TwpES2meBqMKz_Znwx w_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"S96TwpES2meBqMKz_Zn wxw_VumSUMP-v","name":"First Floor (Dining Room)","can_heat":true,"can_cool":false,"target_temperature_ c":21.0,"target_temperature_f":70,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":74,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Dining Room","name_long":"First Floor Thermostat (Dining Room)","is_online":true,"last_connection":"2018-11-03T23:25:45.969Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbIaG96_52eMvA_VumSUMP-v":{"name":"Basement (Laundry and Boiler Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Laundry and Boiler Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.923Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v":{"name":"Basement (Office Area)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Office Area)","is_online":true,"last_connection":"2018-11-03T21:19:57.095Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v":{"name":"First Floor Hallway (Hallway and 1st Floor Bedrooms)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"bp 9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ","device_id":"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v","where_name":"First Floor Hallway","name_long":"First Floor Hallway Nest Protect (Hallway and 1st Floor Bedrooms)","is_online":true,"last_connection":"2018-11-03T21:19:56.860Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false},"cw2LlF6qsbJ6blV1w9asew_VumSUMP-v":{"name":"Second Floor (Bryans Bedroom)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"cw2LlF6qsbJ6blV1w9asew_Vu mSUMP-v","where_name":"Second Floor","name_long":"Second Floor Nest Protect (Bryans Bedroom)","is_online":true,"last_connection":"2018-11-03T21:19:56.952Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v":{"name":"First Floor (Kitchen and Dining Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"u8 FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zDmw","devic e_id":"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","where_name":"First Floor","name_long":"First Floor Nest Protect (Kitchen and Dining Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.972Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:21.000Z"}}},"structures":{"dLgC7sfKoPrJ3j_umj8vLy0z gpMXNmLfU66XypSmQzeWWm2Jhvv75g":{"smoke_co_alarms":["cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","cw2LlF6qsbJ6blV1w9asew_VumSUMP-v","cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v"],"name":"Sweetie 51","country_code":"US","time_zone":"America/New_York","away":"home","thermostats":["gi6tL1If6GiebP7dxtk_gA_VumSUMP-v","gi6tL1If6Gie47mRVAZnVg_VumSUMP-v","gi6tL1If6GimWiK3RdWU2A_VumSUMP-v","S96TwpES2meBqMKz_Znwxw_VumSUMP-v"],"structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSmQze WWm2Jhvv75g","co_alarm_state":"ok","smoke_alarm_state":"ok", "wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK 98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ":{"where_id":"e4Fz I0k3ounJK98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ","name":" Bryan’s Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqR wg9hA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTEZUqMqRwg9hA","name":"Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"Den"},"e4FzI0k3 ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g":{"where_id": "e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","na me":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zD mw":{"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe 2_xR325zDmw","name":"First Floor"},"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA":{"where_id":"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA","name":"First Floor Dining Room"},"bp9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ":{"where_id":"bp9f8QEcqI6odJrlekOrbosohQBEGZF_V FQhPh9x_-Rbge88kLWanQ","name":"First Floor Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqF CpQxg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTGSJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTFcdiDipAgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"9iJ9Ni3dbnLgNWTTaoF17DIhfJag O3rvbxwQb5wCNlxBP9xFcRSdHw":{"where_id":"9iJ9Ni3dbnLgNWTTaoF 17DIhfJagO3rvbxwQb5wCNlxBP9xFcRSdHw","name":"Kitchen and Dining Room"},"EieUyv23YxRdcfOQEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw":{"where_id":"EieUyv23YxRdcfO QEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw","name":"Laundry Boiler Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj 6A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG qA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBTCTsFpxMSw rDEag":{"where_id":"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBT CTsFpxMSwrDEag","name":"Matts-Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA":{"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","name":"Second Floor"},"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2FhZE6lqzr2 8vw":{"where_id":"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2F hZE6lqzr28vw","name":"Second Floor Bryans Bedroom"},"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQl4xptz0dx yg7Pg":{"where_id":"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQ l4xptz0dxyg7Pg","name":"Second Floor Matt's Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHmMVMfI ExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":"Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"}}}},"metadata":{"access_token ":"c.ke2aKn4Lk468brOmNKH5VbdDconBThzoYlZn8yfmrf5zNzQPCnsFR79 ghvcx9QT7xr4MvjOINMi4yH4CNUDBw8QLVMd9rNI0ox518yZk7U6mH1qN3Q2 Lfo1nuKPYG9flbnG0Fdao6Mbo7bWL","client_version":5,"user_id": "z.1.1.qQrY0apShZDvWckwTv4cwPIalTd3gTx58uVTyVvk6Js="}}}
      Nov-03 7:25:46 PM Nest DEBUG event: put
      Nov-03 7:25:46 PM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GiebP7dxtk_gA_ VumSUMP-v":{"humidity":55,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"gi6tL1If6GiebP7dxtk_gA_Vu mSUMP-v","name":"Second Floor (Matts Bedroom)","can_heat":true,"can_cool":false,"target_temperatu re_c":21.0,"target_temperature_f":70,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":22.0,"ambient_temperature_f":72,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":4.0,"away_temperature_low_f":40,"eco_temperature_high_c" :24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":4. 0,"eco_temperature_low_f":40,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"dLgC7sfKoPr J3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Second Floor","label":"Matts Bedroom","name_long":"Second Floor Thermostat (Matts Bedroom)","is_online":true,"last_connection":"2018-11-03T23:21:32.629Z","hvac_state":"off"},"gi6tL1If6GimWiK3RdWU2 A_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"gi6tL1If6GimWiK3RdWU 2A_VumSUMP-v","name":"Basement (Family Room)","can_heat":true,"can_cool":false,"target_temperature_ c":18.5,"target_temperature_f":66,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":21.5,"ambient_temperature_f":72,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"Family Room","name_long":"Basement Thermostat (Family Room)","is_online":true,"last_connection":"2018-11-03T23:21:31.220Z","hvac_state":"off"},"gi6tL1If6Gie47mRVAZnV g_VumSUMP-v":{"humidity":45,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"gi6tL1If6Gie47mRVAZ nVg_VumSUMP-v","name":"First Floor (Hallway)","can_heat":true,"can_cool":true,"target_temperatu re_c":20.5,"target_temperature_f":69,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":20.0,"ambient_temperature_f":69,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c ":24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":2 1.0,"eco_temperature_low_f":70,"is_locked":false,"locked_tem p_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22. 0,"locked_temp_max_f":72,"sunlight_correction_active":false, "sunlight_correction_enabled":true,"structure_id":"dLgC7sfKo PrJ3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_ac tive":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Hallway","name_long":"First Floor Thermostat (Hallway)","is_online":true,"last_connection":"2018-11-03T23:21:57.842Z","hvac_state":"off"},"S96TwpES2meBqMKz_Znwx w_VumSUMP-v":{"humidity":45,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"S96TwpES2meBqMKz_Zn wxw_VumSUMP-v","name":"First Floor (Dining Room)","can_heat":true,"can_cool":false,"target_temperature_ c":21.0,"target_temperature_f":70,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":74,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Dining Room","name_long":"First Floor Thermostat (Dining Room)","is_online":true,"last_connection":"2018-11-03T23:25:45.969Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbIaG96_52eMvA_VumSUMP-v":{"name":"Basement (Laundry and Boiler Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Laundry and Boiler Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.923Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v":{"name":"Basement (Office Area)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Office Area)","is_online":true,"last_connection":"2018-11-03T21:19:57.095Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v":{"name":"First Floor Hallway (Hallway and 1st Floor Bedrooms)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"bp 9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ","device_id":"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v","where_name":"First Floor Hallway","name_long":"First Floor Hallway Nest Protect (Hallway and 1st Floor Bedrooms)","is_online":true,"last_connection":"2018-11-03T21:19:56.860Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false},"cw2LlF6qsbJ6blV1w9asew_VumSUMP-v":{"name":"Second Floor (Bryans Bedroom)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"cw2LlF6qsbJ6blV1w9asew_Vu mSUMP-v","where_name":"Second Floor","name_long":"Second Floor Nest Protect (Bryans Bedroom)","is_online":true,"last_connection":"2018-11-03T21:19:56.952Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v":{"name":"First Floor (Kitchen and Dining Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"u8 FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zDmw","devic e_id":"cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","where_name":"First Floor","name_long":"First Floor Nest Protect (Kitchen and Dining Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.972Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:21.000Z"}}},"structures":{"dLgC7sfKoPrJ3j_umj8vLy0z gpMXNmLfU66XypSmQzeWWm2Jhvv75g":{"smoke_co_alarms":["cw2LlF6qsbLJjBIpweO9tQ_VumSUMP-v","cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","cw2LlF6qsbJ6blV1w9asew_VumSUMP-v","cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v"],"name":"Sweetie 51","country_code":"US","time_zone":"America/New_York","away":"home","thermostats":["gi6tL1If6GiebP7dxtk_gA_VumSUMP-v","gi6tL1If6Gie47mRVAZnVg_VumSUMP-v","gi6tL1If6GimWiK3RdWU2A_VumSUMP-v","S96TwpES2meBqMKz_Znwxw_VumSUMP-v"],"structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSmQze WWm2Jhvv75g","co_alarm_state":"ok","smoke_alarm_state":"ok", "wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK 98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ":{"where_id":"e4Fz I0k3ounJK98jBApsiEQQasEHRqOR2hLlLfnCPwd3A9YJSLjPWQ","name":" Bryan’s Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqR wg9hA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTEZUqMqRwg9hA","name":"Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"Den"},"e4FzI0k3 ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g":{"where_id": "e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","na me":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe2_xR325zD mw":{"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdFzpHB0smQIReozGe 2_xR325zDmw","name":"First Floor"},"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA":{"where_id":"ruSPUC5cZkNU1Hc3Q5Ow2EFyuXBmJhzFNy_L5-NZknulitwjNG-mJA","name":"First Floor Dining Room"},"bp9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ":{"where_id":"bp9f8QEcqI6odJrlekOrbosohQBEGZF_V FQhPh9x_-Rbge88kLWanQ","name":"First Floor Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqF CpQxg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTGSJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTFcdiDipAgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"9iJ9Ni3dbnLgNWTTaoF17DIhfJag O3rvbxwQb5wCNlxBP9xFcRSdHw":{"where_id":"9iJ9Ni3dbnLgNWTTaoF 17DIhfJagO3rvbxwQb5wCNlxBP9xFcRSdHw","name":"Kitchen and Dining Room"},"EieUyv23YxRdcfOQEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw":{"where_id":"EieUyv23YxRdcfO QEtPCzL1-vISkGFQPZqXiMcjs7YUu873hvY8vnw","name":"Laundry Boiler Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj 6A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG qA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBTCTsFpxMSw rDEag":{"where_id":"viDzMe17BYgBbOAMaSkEiLOvq5QSMh0xbCo7OzBT CTsFpxMSwrDEag","name":"Matts-Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA":{"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","name":"Second Floor"},"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2FhZE6lqzr2 8vw":{"where_id":"fC7GY1tcpEXYfslWjcilig4ysi5mm6JMFsWW0m5P2F hZE6lqzr28vw","name":"Second Floor Bryans Bedroom"},"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQl4xptz0dx yg7Pg":{"where_id":"bXZ28K3DpxUzFegrtegkQYTEZqpgG67Rx964NKkQ l4xptz0dxyg7Pg","name":"Second Floor Matt's Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHmMVMfI ExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":"Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"}}}},"metadata":{"access_token ":"c.ke2aKn4Lk468brOmNKH5VbdDconBThzoYlZn8yfmrf5zNzQPCnsFR79 ghvcx9QT7xr4MvjOINMi4yH4CNUDBw8QLVMd9rNI0ox518yZk7U6mH1qN3Q2 Lfo1nuKPYG9flbnG0Fdao6Mbo7bWL","client_version":5,"user_id": "z.1.1.qQrY0apShZDvWckwTv4cwPIalTd3gTx58uVTyVvk6Js="}}}
      Nov-03 7:25:46 PM Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GiebP7dxtk_gA_ VumSUMP-v":{"humidity":55,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"gi6tL1If6GiebP7dxtk_gA_Vu mSUMP-v","name":"Second Floor (Matts Bedroom)","can_heat":true,"can_cool":false,"target_temperatu re_c":21.0,"target_temperature_f":70,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":22.0,"ambient_temperature_f":72,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":4.0,"away_temperature_low_f":40,"eco_temperature_high_c" :24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":4. 0,"eco_temperature_low_f":40,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"dLgC7sfKoPr J3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Second Floor","label":"Matts Bedroom","name_long":"Second Floor Thermostat (Matts Bedroom)","is_online":true,"last_connection":"2018-11-03T23:21:32.629Z","hvac_state":"off"},"gi6tL1If6GimWiK3RdWU2 A_VumSUMP-v":{"humidity":50,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"gi6tL1If6GimWiK3RdWU 2A_VumSUMP-v","name":"Basement (Family Room)","can_heat":true,"can_cool":false,"target_temperature_ c":18.5,"target_temperature_f":66,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":21.5,"ambient_temperature_f":72,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"Family Room","name_long":"Basement Thermostat (Family Room)","is_online":true,"last_connection":"2018-11-03T23:21:31.220Z","hvac_state":"off"},"gi6tL1If6Gie47mRVAZnV g_VumSUMP-v":{"humidity":45,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"gi6tL1If6Gie47mRVAZ nVg_VumSUMP-v","name":"First Floor (Hallway)","can_heat":true,"can_cool":true,"target_temperatu re_c":20.5,"target_temperature_f":69,"target_temperature_hig h_c":24.0,"target_temperature_high_f":75,"target_temperature _low_c":20.0,"target_temperature_low_f":68,"ambient_temperat ure_c":20.0,"ambient_temperature_f":69,"away_temperature_hig h_c":24.0,"away_temperature_high_f":76,"away_temperature_low _c":21.0,"away_temperature_low_f":70,"eco_temperature_high_c ":24.0,"eco_temperature_high_f":76,"eco_temperature_low_c":2 1.0,"eco_temperature_low_f":70,"is_locked":false,"locked_tem p_min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22. 0,"locked_temp_max_f":72,"sunlight_correction_active":false, "sunlight_correction_enabled":true,"structure_id":"dLgC7sfKo PrJ3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_ac tive":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Hallway","name_long":"First Floor Thermostat (Hallway)","is_online":true,"last_connection":"2018-11-03T23:21:57.842Z","hvac_state":"off"},"S96TwpES2meBqMKz_Znwx w_VumSUMP-v":{"humidity":40,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.8.2-1","has_leaf":false,"where_id":"u8FJjs3NQdkkMWJ4ZCEREtnxWcdF zpHB0smQIReozGe2_xR325zDmw","device_id":"S96TwpES2meBqMKz_Zn wxw_VumSUMP-v","name":"First Floor (Dining Room)","can_heat":true,"can_cool":false,"target_temperature_ c":21.0,"target_temperature_f":70,"target_temperature_high_c ":24.0,"target_temperature_high_f":75,"target_temperature_lo w_c":20.0,"target_temperature_low_f":68,"ambient_temperature _c":23.0,"ambient_temperature_f":74,"away_temperature_high_c ":24.0,"away_temperature_high_f":76,"away_temperature_low_c" :12.5,"away_temperature_low_f":55,"eco_temperature_high_c":2 4.0,"eco_temperature_high_f":76,"eco_temperature_low_c":12.5 ,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_m in_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0," locked_temp_max_f":72,"sunlight_correction_active":false,"su nlight_correction_enabled":true,"structure_id":"dLgC7sfKoPrJ 3j_umj8vLy0zgpMXNmLfU66XypSmQzeWWm2Jhvv75g","fan_timer_activ e":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"First Floor","label":"Dining Room","name_long":"First Floor Thermostat (Dining Room)","is_online":true,"last_connection":"2018-11-03T23:25:45.969Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbIaG96_52eMvA_VumSUMP-v":{"name":"Basement (Laundry and Boiler Room)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbIaG96_52eMvA_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Laundry and Boiler Room)","is_online":true,"last_connection":"2018-11-03T21:19:56.923Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v":{"name":"Basement (Office Area)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","devic e_id":"cw2LlF6qsbLhUWz553-sjg_VumSUMP-v","where_name":"Basement","name_long":"Basement Nest Protect (Office Area)","is_online":true,"last_connection":"2018-11-03T21:19:57.095Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-08-05T20:53:40.000Z"},"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v":{"name":"First Floor Hallway (Hallway and 1st Floor Bedrooms)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"bp 9f8QEcqI6odJrlekOrbosohQBEGZF_VFQhPh9x_-Rbge88kLWanQ","device_id":"cw2LlF6qsbJNCIPPiwLsjQ_VumSUMP-v","where_name":"First Floor Hallway","name_long":"First Floor Hallway Nest Protect (Hallway and 1st Floor Bedrooms)","is_online":true,"last_connection":"2018-11-03T21:19:56.860Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false},"cw2LlF6qsbJ6blV1w9asew_VumSUMP-v":{"name":"Second Floor (Bryans Bedroom)","locale":"en-US","structure_id":"dLgC7sfKoPrJ3j_umj8vLy0zgpMXNmLfU66XypSm QzeWWm2Jhvv75g","software_version":"3.1.4rc3","where_id":"q-GmOcfH0bHgN2fhLVomdQ4kh-vtmqYeL-d1XRkqnUX8iDDVhIPmWA","device_id":"cw2LlF6qsbJ6blV1w9asew_Vu mSUMP-v","where_name":"Second Floor","name_long":"Second Floor Nest Protect (Bryans Bedroom)","is_online":true,"last_connection":"2018-11-03T21:19:56.952Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_ac
