Stumped immediately
  • Stumped immediately
    Followed the directions and authorized the Nest plugin. Running HS3 on the SEL controller. Web interface shows my two nest locations and "home" for one and "away" for the other, which is correct. None of the actual devices are visible. Looking at other queries I see you need to see the debug log so pasted the last few minutes' worth below. Not sure where to start. Thanks in advance for your help.
    -Andrew
    Dec-02 11:44:58 Nest DEBUG data: null
    Dec-02 11:44:58 Nest DEBUG event: keep-alive
    Dec-02 11:44:43 Nest DEBUG System.MissingMethodException: Method not found: double NestSharp.NestThermostat.get_eco_temperature_high_f() at HSPI_Nest.NestApp.OnNestDataUpdated (System.Object o, NestSharp.NestData data) [0x00094] in :0
    Dec-02 11:44:43 Nest ERROR Method not found: double NestSharp.NestThermostat.get_eco_temperature_high_f()
    Dec-02 11:44:43 Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"jhpfa2hTud79DcBweJ8uzg_ VumSUMP-v":{"humidity":40,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.9.1-6","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"jhpfa2hTud79DcBweJ8u zg_VumSUMP-v","name":"Basement","can_heat":true,"can_cool":true,"target _temperature_c":16.0,"target_temperature_f":61,"target_tempe rature_high_c":24.0,"target_temperature_high_f":75,"target_t emperature_low_c":20.0,"target_temperature_low_f":68,"ambien t_temperature_c":19.5,"ambient_temperature_f":68,"away_tempe rature_high_c":27.5,"away_temperature_high_f":82,"away_tempe rature_low_c":10.0,"away_temperature_low_f":50,"eco_temperat ure_high_c":27.5,"eco_temperature_high_f":82,"eco_temperatur e_low_c":10.0,"eco_temperature_low_f":50,"is_locked":false," locked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_temp_ max_c":22.0,"locked_temp_max_f":72,"sunlight_correction_acti ve":false,"sunlight_correction_enabled":true,"structure_id": "R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","fan_timer_active":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"","nam e_long":"Basement Thermostat","is_online":true,"last_connection":"2018-12-02T16:30:18.324Z","hvac_state":"off"},"jhpfa2hTud7VcEDVwXnrB g_VumSUMP-v":{"humidity":35,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.9.1-6","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTG9A7cHHQwbjw","device_id":"jhpfa2hTud7VcEDVwXn rBg_VumSUMP-v","name":"Downstairs","can_heat":true,"can_cool":true,"targ et_temperature_c":21.0,"target_temperature_f":70,"target_tem perature_high_c":24.0,"target_temperature_high_f":75,"target _temperature_low_c":20.0,"target_temperature_low_f":68,"ambi ent_temperature_c":21.0,"ambient_temperature_f":70,"away_tem perature_high_c":24.5,"away_temperature_high_f":77,"away_tem perature_low_c":12.5,"away_temperature_low_f":55,"eco_temper ature_high_c":24.5,"eco_temperature_high_f":77,"eco_temperat ure_low_c":12.5,"eco_temperature_low_f":55,"is_locked":false ,"locked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_tem p_max_c":22.0,"locked_temp_max_f":72,"sunlight_correction_ac tive":false,"sunlight_correction_enabled":true,"structure_id ":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","fan_timer_active":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":720,"previous_hvac_mo de":"","hvac_mode":"heat","time_to_target":"~0","time_to_tar get_training":"ready","where_name":"Downstairs","label":""," name_long":"Downstairs Thermostat","is_online":true,"last_connection":"2018-12-02T16:44:42.991Z","hvac_state":"off"},"jhpfa2hTud6VFXqKex9wG g_VumSUMP-v":{"humidity":35,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.9.1-6","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGp8x7lb5eAZA","device_id":"jhpfa2hTud6VFXqKex9 wGg_VumSUMP-v","name":"Master Bedroom","can_heat":true,"can_cool":true,"target_temperature _c":20.5,"target_temperature_f":70,"target_temperature_high_ c":24.0,"target_temperature_high_f":75,"target_temperature_l ow_c":20.0,"target_temperature_low_f":68,"ambient_temperatur e_c":21.0,"ambient_temperature_f":70,"away_temperature_high_ c":24.5,"away_temperature_high_f":77,"away_temperature_low_c ":12.5,"away_temperature_low_f":55,"eco_temperature_high_c": 24.5,"eco_temperature_high_f":77,"eco_temperature_low_c":12. 5,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"R79Yyrarqdw Nec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","fan_timer_active":true,"fan_timer_timeout":"2018-12-02T16:53:04.000Z","fan_timer_duration":720,"previous_hvac_mo de":"","hvac_mode":"heat","time_to_target":"~0","time_to_tar get_training":"ready","where_name":"Master Bedroom","label":"","name_long":"Master Bedroom Thermostat","is_online":true,"last_connection":"2018-12-02T16:44:41.932Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbKCDgOS_DWaVw_VumSUMP-v":{"name":"Bunk Room (Bunk Room)","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"cM3FFZRpi7J34o eXHoRED9bD9v9jcrRz1q3NJIsGD4Ez5Q-l60Ae0g","device_id":"cw2LlF6qsbKCDgOS_DWaVw_VumSUMP-v","where_name":"Bunk Room","name_long":"Bunk Room Nest Protect (Bunk Room)","is_online":true,"last_connection":"2018-12-01T19:07:06.504Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbIC7tdKHdEmog_VumSUMP-v":{"name":"guest bedroom","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"EK_V79J_7it40f CBhy3FDAAcBO-iJZxqRqyp9tdBOEvqjm4fxHNPPQ","device_id":"cw2LlF6qsbIC7tdKHd Emog_VumSUMP-v","where_name":"guest bedroom","name_long":"guest bedroom Nest Protect","is_online":true,"last_connection":"2018-12-02T08:37:38.739Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbKezVUlamBwZg_VumSUMP-v":{"name":"Master Bedroom (Master)","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eAZA","device_id":"cw2Ll F6qsbKezVUlamBwZg_VumSUMP-v","where_name":"Master Bedroom","name_long":"Master Bedroom Nest Protect (Master)","is_online":true,"last_connection":"2018-12-02T15:27:01.269Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:56:57.000Z"},"cw2LlF6qsbI9-3Yz8mxZjw_VumSUMP-v":{"locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","device_id":"cw2Ll F6qsbI9-3Yz8mxZjw_VumSUMP-v","where_name":"Basement","name":"Basement","name_long":"Ba sement Nest Protect","is_online":true,"last_connection":"2018-12-02T16:25:11.069Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbLqA03MjrNVDQ_VumSUMP-v":{"name":"Kitchen","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw","device_id":"cw2Ll F6qsbLqA03MjrNVDQ_VumSUMP-v","where_name":"Kitchen","name_long":"Kitchen Nest Protect","is_online":true,"last_connection":"2018-12-02T04:32:35.228Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbI2W2OjoNaK5g_VumSUMP-v":{"locale":"en-US","structure_id":"-enKqJC63ZecTFKuCR8Mrh2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"H5yDjsMy1mOk v-CjsBlTWuH1z8GtPvJlJ-MuMSGXKDjnBdrolvZDKQ","device_id":"cw2LlF6qsbI2W2OjoNaK5g_Vu mSUMP-v","where_name":"apartment","name":"apartment","name_long":" apartment Nest Protect","is_online":true,"last_connection":"2018-12-01T10:53:36.077Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"yellow","is_man ual_test_active":false,"last_manual_test_time":"2018-09-18T04:06:19.000Z"},"cw2LlF6qsbJ00jxLMM9T6g_VumSUMP-v":{"locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"Lpix1CTtYDaoIP Wg3Bs4jRSB0j6WV1fJ_GptBKkClZkMGQclJ7wt-A","device_id":"cw2LlF6qsbJ00jxLMM9T6g_VumSUMP-v","where_name":"game room","name":"game room","name_long":"game room Nest Protect","is_online":true,"last_connection":"2018-12-02T16:16:18.628Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"}},"cameras":{"byyc3Cp68b50U5P88X-S8E2uHdqGPov_RewMYtVYtA0P1bpklDD_rw":{"name":"Garage","softw are_version":"4620002","where_id":"SX5jf4lk0fhvhvICXFpN6ZmPJ 2KW9CB2xJKLGbIgC5MSyIBY7nvpeg","device_id":"byyc3Cp68b50U5P8 8X-S8E2uHdqGPov_RewMYtVYtA0P1bpklDD_rw","structure_id":"R79Yyra rqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","is_online":true,"is_streaming":true,"is_audio_input_ena bled":true,"last_is_online_change":"2018-11-29T06:56:43.000Z","is_video_history_enabled":true,"is_public _share_enabled":false,"last_event":{"has_sound":false,"has_m otion":true,"has_person":false,"start_time":"2018-12-02T15:47:30.793Z","end_time":"2018-12-02T15:47:38.393Z","urls_expire_time":"2018-12-12T15:47:30.793Z","web_url":"https://home.nest.com/cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/3llW4SgvE8gQenT3jWlslg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/3llW4SgvE8gQenT3jWlslg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","image_url":"https://www.dropcam.com/api/wwn.get_image/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu6cE6SmQVhW-wUyBGkB9mBVgKa-5ypeFzKg-b1CfWYjhjJtl0uuImGaJDpGRfC-sIdwj48DEjoAoZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8 HH_OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg2 8bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","animated_image_url":"https://www.dropcam.com/api/wwn.get_animated_image/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu6cE6SmQVhW-wUyBGkB9mBVgKa-5ypeFzKg-b1CfWYjhjJtl0uuImGaJDpGRfC-sIdwj48DEjoAoZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8 HH_OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg2 8bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"},"name_long":"Garage Camera","web_url":"https://home.nest.com/cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","snapshot_url":"https://www.dropcam.com/api/wwn.get_snapshot/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNyMC1TUWVtMWQ5WFEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"},"Pf9StMlw835uCff8nVNIk9VQ_6kfjW7LdBqtYAW0e2YP1bpklDD_rw ":{"name":"Living Room","software_version":"4620002","where_id":"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","device_id":"Pf9S tMlw835uCff8nVNIk9VQ_6kfjW7LdBqtYAW0e2YP1bpklDD_rw","structu re_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","is_online":true,"is_streaming":false,"is_audio_input_en abled":true,"last_is_online_change":"2018-12-02T14:30:00.000Z","is_video_history_enabled":true,"is_public _share_enabled":false,"last_event":{"has_sound":false,"has_m otion":false,"has_person":true,"start_time":"2018-12-01T18:33:01.981Z","end_time":"2018-12-01T18:33:13.947Z","urls_expire_time":"2018-12-11T18:33:01.981Z","web_url":"https://home.nest.com/cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/ielWkxOBdeNLXtA44Lzwvg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/ielWkxOBdeNLXtA44Lzwvg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","image_url":"https://www.dropcam.com/api/wwn.get_image/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu9ZPW0nq31btR3WALtg9C0_SJC9Bt9OmhAnUrfe8w14acb 0JLGsng51S4wuxnKRUI2s9U-vr_hcTZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd 9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","animated_image_url":"https://www.dropcam.com/api/wwn.get_animated_image/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu9ZPW0nq31btR3WALtg9C0_SJC9Bt9OmhAnUrfe8w14acb 0JLGsng51S4wuxnKRUI2s9U-vr_hcTZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd 9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"},"name_long":"Living Room Camera","web_url":"https://home.nest.com/cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","snapshot_url":"https://www.dropcam.com/api/wwn.get_snapshot/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNyZGxQX0c1dHVZS3caNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"}}},"structures":{"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ":{"smoke_co_alarms":["cw2LlF6qsbKCDgOS_DWaVw_VumSUMP-v","cw2LlF6qsbLqA03MjrNVDQ_VumSUMP-v","cw2LlF6qsbIC7tdKHdEmog_VumSUMP-v","cw2LlF6qsbKezVUlamBwZg_VumSUMP-v","cw2LlF6qsbI9-3Yz8mxZjw_VumSUMP-v","cw2LlF6qsbJ00jxLMM9T6g_VumSUMP-v"],"name":"Keeler","country_code":"US","time_zone":"America/New_York","away":"home","thermostats":["jhpfa2hTud6VFXqKex9wGg_VumSUMP-v","jhpfa2hTud79DcBweJ8uzg_VumSUMP-v","jhpfa2hTud7VcEDVwXnrBg_VumSUMP-v"],"structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","co_alarm_state":"ok","smoke_alarm_state":"ok","wheres": {"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3Xg3Pw":{" where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"cM3FFZRpi7J34 oeXHoRED9bD9v9jcrRz1q3NJIsGD4Ez5Q-l60Ae0g":{"where_id":"cM3FFZRpi7J34oeXHoRED9bD9v9jcrRz1q3NJI sGD4Ez5Q-l60Ae0g","name":"Bunk Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9 hA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE ZUqMqRwg9hA","name":"Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOE zrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI0k3ounJK98jBApsiD 3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"Den"},"e4FzI0k3oun JK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g":{"where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","name" :"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqFCpQ xg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG SJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"Lpix1CTtYDaoIPWg3Bs4jRSB0j6WV1fJ_GptBKkClZkMGQclJ7wt-A":{"where_id":"Lpix1CTtYDaoIPWg3Bs4jRSB0j6WV1fJ_GptBKkClZkM GQclJ7wt-A","name":"game room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"SX5jf4lk0fhvhvICXFpN6ZmPJ2KW9CB2xJKL GbIgC5MSyIBY7nvpeg":{"where_id":"SX5jf4lk0fhvhvICXFpN6ZmPJ2K W9CB2xJKLGbIgC5MSyIBY7nvpeg","name":"Garage"},"EK_V79J_7it40 fCBhy3FDAAcBO-iJZxqRqyp9tdBOEvqjm4fxHNPPQ":{"where_id":"EK_V79J_7it40fCBhy 3FDAAcBO-iJZxqRqyp9tdBOEvqjm4fxHNPPQ","name":"guest bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFcdiDip AgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiJ6Lo6Sp _7HYWuw5bYHWbWz-Fibb-PMOIQ":{"where_id":"e4FzI0k3ounJK98jBApsiJ6Lo6Sp_7HYWuw5bYHW bWz-Fibb-PMOIQ","name":"Library"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTHmMVMfIExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":" Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"},"rpEPAZvX7Uedr-fUP4ISLb6ps-2HvZ_6tl2bTfJyvWVyMpw_0ZOykg":{"where_id":"rpEPAZvX7Uedr-fUP4ISLb6ps-2HvZ_6tl2bTfJyvWVyMpw_0ZOykg","name":"Workout Room"}},"cameras":["Pf9StMlw835uCff8nVNIk9VQ_6kfjW7LdBqtYAW0e2YP1bpklDD_rw","by yc3Cp68b50U5P88X-S8E2uHdqGPov_RewMYtVYtA0P1bpklDD_rw"]},"-enKqJC63ZecTFKuCR8Mrh2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ":{"smoke_co_alarms":["cw2LlF6qsbI2W2OjoNaK5g_VumSUMP-v"],"name":"Apartment","country_code":"US","time_zone":"Amer ica/New_York","away":"away","structure_id":"-enKqJC63ZecTFKuCR8Mrh2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","co_alarm_state":"ok","smoke_alarm_state":"ok","wheres": {"H5yDjsMy1mOkv-CjsBlTWuH1z8GtPvJlJ-MuMSGXKDjnBdrolvZDKQ":{"where_id":"H5yDjsMy1mOkv-CjsBlTWuH1z8GtPvJlJ-MuMSGXKDjnBdrolvZDKQ","name":"apartment"},"dPBlunSHE0voHzocQ DzP85nMasM73FnTHFktGtgBBpx5NT-z-A6AoA":{"where_id":"dPBlunSHE0voHzocQDzP85nMasM73FnTHFktGtgB Bpx5NT-z-A6AoA","name":""},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TE01lWQ3Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEz rxhFivj_GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ou nJK98jBApsiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9hA":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9hA","name":" Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRs rA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 2QFAGvJRsrA","name":"Den"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEz rxhFivj_GTFsTZUOmdSi_g":{"where_id":"e4FzI0k3ounJK98jBApsiD3 MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","name":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqFCpQ xg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG SJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTFcdiDipAgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTHmMVMfIExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":" Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"}}}},"metadata":{"access_token ":"c.0Oxljhp5lgCsUHWfaDVBpDjL9QctH67YaAIYZ5ywI816H86rPZpfGbX osxU52znUBMhjdGIpGPAyGJopsaszcyolfDm1tqhiAPU2LSiTtGgrzi0vTXT ALsrWDEcSLl3Y3DI5CVAib0WhmhgE","client_version":5,"user_id": "z.1.1.BcfxmNPzUEd5BlmDeVhgYNAF474OIKe95zlgEpBe6jE="}}}
    Dec-02 11:44:43 Nest DEBUG event: put
    Dec-02 11:44:43 Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"jhpfa2hTud79DcBweJ8uzg_ VumSUMP-v":{"humidity":40,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.9.1-6","has_leaf":true,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhH OEzrxhFivj_GTFP3uSH6epqyw","device_id":"jhpfa2hTud79DcBweJ8u zg_VumSUMP-v","name":"Basement","can_heat":true,"can_cool":true,"target _temperature_c":16.0,"target_temperature_f":61,"target_tempe rature_high_c":24.0,"target_temperature_high_f":75,"target_t emperature_low_c":20.0,"target_temperature_low_f":68,"ambien t_temperature_c":19.5,"ambient_temperature_f":68,"away_tempe rature_high_c":27.5,"away_temperature_high_f":82,"away_tempe rature_low_c":10.0,"away_temperature_low_f":50,"eco_temperat ure_high_c":27.5,"eco_temperature_high_f":82,"eco_temperatur e_low_c":10.0,"eco_temperature_low_f":50,"is_locked":false," locked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_temp_ max_c":22.0,"locked_temp_max_f":72,"sunlight_correction_acti ve":false,"sunlight_correction_enabled":true,"structure_id": "R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","fan_timer_active":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":15,"previous_hvac_mod e":"","hvac_mode":"heat","time_to_target":"~0","time_to_targ et_training":"ready","where_name":"Basement","label":"","nam e_long":"Basement Thermostat","is_online":true,"last_connection":"2018-12-02T16:30:18.324Z","hvac_state":"off"},"jhpfa2hTud7VcEDVwXnrB g_VumSUMP-v":{"humidity":35,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.9.1-6","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTG9A7cHHQwbjw","device_id":"jhpfa2hTud7VcEDVwXn rBg_VumSUMP-v","name":"Downstairs","can_heat":true,"can_cool":true,"targ et_temperature_c":21.0,"target_temperature_f":70,"target_tem perature_high_c":24.0,"target_temperature_high_f":75,"target _temperature_low_c":20.0,"target_temperature_low_f":68,"ambi ent_temperature_c":21.0,"ambient_temperature_f":70,"away_tem perature_high_c":24.5,"away_temperature_high_f":77,"away_tem perature_low_c":12.5,"away_temperature_low_f":55,"eco_temper ature_high_c":24.5,"eco_temperature_high_f":77,"eco_temperat ure_low_c":12.5,"eco_temperature_low_f":55,"is_locked":false ,"locked_temp_min_c":20.0,"locked_temp_min_f":68,"locked_tem p_max_c":22.0,"locked_temp_max_f":72,"sunlight_correction_ac tive":false,"sunlight_correction_enabled":true,"structure_id ":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","fan_timer_active":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","fan_timer_duration":720,"previous_hvac_mo de":"","hvac_mode":"heat","time_to_target":"~0","time_to_tar get_training":"ready","where_name":"Downstairs","label":""," name_long":"Downstairs Thermostat","is_online":true,"last_connection":"2018-12-02T16:44:42.990Z","hvac_state":"off"},"jhpfa2hTud6VFXqKex9wG g_VumSUMP-v":{"humidity":35,"locale":"en-GB","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.9.1-6","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGp8x7lb5eAZA","device_id":"jhpfa2hTud6VFXqKex9 wGg_VumSUMP-v","name":"Master Bedroom","can_heat":true,"can_cool":true,"target_temperature _c":20.5,"target_temperature_f":70,"target_temperature_high_ c":24.0,"target_temperature_high_f":75,"target_temperature_l ow_c":20.0,"target_temperature_low_f":68,"ambient_temperatur e_c":21.0,"ambient_temperature_f":70,"away_temperature_high_ c":24.5,"away_temperature_high_f":77,"away_temperature_low_c ":12.5,"away_temperature_low_f":55,"eco_temperature_high_c": 24.5,"eco_temperature_high_f":77,"eco_temperature_low_c":12. 5,"eco_temperature_low_f":55,"is_locked":false,"locked_temp_ min_c":20.0,"locked_temp_min_f":68,"locked_temp_max_c":22.0, "locked_temp_max_f":72,"sunlight_correction_active":false,"s unlight_correction_enabled":true,"structure_id":"R79Yyrarqdw Nec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","fan_timer_active":true,"fan_timer_timeout":"2018-12-02T16:53:04.000Z","fan_timer_duration":720,"previous_hvac_mo de":"","hvac_mode":"heat","time_to_target":"~0","time_to_tar get_training":"ready","where_name":"Master Bedroom","label":"","name_long":"Master Bedroom Thermostat","is_online":true,"last_connection":"2018-12-02T16:44:41.932Z","hvac_state":"off"}},"smoke_co_alarms":{"c w2LlF6qsbKCDgOS_DWaVw_VumSUMP-v":{"name":"Bunk Room (Bunk Room)","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"cM3FFZRpi7J34o eXHoRED9bD9v9jcrRz1q3NJIsGD4Ez5Q-l60Ae0g","device_id":"cw2LlF6qsbKCDgOS_DWaVw_VumSUMP-v","where_name":"Bunk Room","name_long":"Bunk Room Nest Protect (Bunk Room)","is_online":true,"last_connection":"2018-12-01T19:07:06.504Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbIC7tdKHdEmog_VumSUMP-v":{"name":"guest bedroom","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"EK_V79J_7it40f CBhy3FDAAcBO-iJZxqRqyp9tdBOEvqjm4fxHNPPQ","device_id":"cw2LlF6qsbIC7tdKHd Emog_VumSUMP-v","where_name":"guest bedroom","name_long":"guest bedroom Nest Protect","is_online":true,"last_connection":"2018-12-02T08:37:38.739Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbKezVUlamBwZg_VumSUMP-v":{"name":"Master Bedroom (Master)","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eAZA","device_id":"cw2Ll F6qsbKezVUlamBwZg_VumSUMP-v","where_name":"Master Bedroom","name_long":"Master Bedroom Nest Protect (Master)","is_online":true,"last_connection":"2018-12-02T15:27:01.269Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:56:57.000Z"},"cw2LlF6qsbI9-3Yz8mxZjw_VumSUMP-v":{"locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","device_id":"cw2Ll F6qsbI9-3Yz8mxZjw_VumSUMP-v","where_name":"Basement","name":"Basement","name_long":"Ba sement Nest Protect","is_online":true,"last_connection":"2018-12-02T16:25:11.069Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbLqA03MjrNVDQ_VumSUMP-v":{"name":"Kitchen","locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"e4FzI0k3ounJK9 8jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw","device_id":"cw2Ll F6qsbLqA03MjrNVDQ_VumSUMP-v","where_name":"Kitchen","name_long":"Kitchen Nest Protect","is_online":true,"last_connection":"2018-12-02T04:32:35.228Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"},"cw2LlF6qsbI2W2OjoNaK5g_VumSUMP-v":{"locale":"en-US","structure_id":"-enKqJC63ZecTFKuCR8Mrh2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"H5yDjsMy1mOk v-CjsBlTWuH1z8GtPvJlJ-MuMSGXKDjnBdrolvZDKQ","device_id":"cw2LlF6qsbI2W2OjoNaK5g_Vu mSUMP-v","where_name":"apartment","name":"apartment","name_long":" apartment Nest Protect","is_online":true,"last_connection":"2018-12-01T10:53:36.077Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"yellow","is_man ual_test_active":false,"last_manual_test_time":"2018-09-18T04:06:19.000Z"},"cw2LlF6qsbJ00jxLMM9T6g_VumSUMP-v":{"locale":"en-US","structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","software_version":"3.1.4rc3","where_id":"Lpix1CTtYDaoIP Wg3Bs4jRSB0j6WV1fJ_GptBKkClZkMGQclJ7wt-A","device_id":"cw2LlF6qsbJ00jxLMM9T6g_VumSUMP-v","where_name":"game room","name":"game room","name_long":"game room Nest Protect","is_online":true,"last_connection":"2018-12-02T16:16:18.628Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"2018-07-14T04:57:16.000Z"}},"cameras":{"byyc3Cp68b50U5P88X-S8E2uHdqGPov_RewMYtVYtA0P1bpklDD_rw":{"name":"Garage","softw are_version":"4620002","where_id":"SX5jf4lk0fhvhvICXFpN6ZmPJ 2KW9CB2xJKLGbIgC5MSyIBY7nvpeg","device_id":"byyc3Cp68b50U5P8 8X-S8E2uHdqGPov_RewMYtVYtA0P1bpklDD_rw","structure_id":"R79Yyra rqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","is_online":true,"is_streaming":true,"is_audio_input_ena bled":true,"last_is_online_change":"2018-11-29T06:56:43.000Z","is_video_history_enabled":true,"is_public _share_enabled":false,"last_event":{"has_sound":false,"has_m otion":true,"has_person":false,"start_time":"2018-12-02T15:47:30.793Z","end_time":"2018-12-02T15:47:38.393Z","urls_expire_time":"2018-12-12T15:47:30.793Z","web_url":"https://home.nest.com/cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/3llW4SgvE8gQenT3jWlslg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/3llW4SgvE8gQenT3jWlslg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","image_url":"https://www.dropcam.com/api/wwn.get_image/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu6cE6SmQVhW-wUyBGkB9mBVgKa-5ypeFzKg-b1CfWYjhjJtl0uuImGaJDpGRfC-sIdwj48DEjoAoZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8 HH_OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg2 8bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","animated_image_url":"https://www.dropcam.com/api/wwn.get_animated_image/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu6cE6SmQVhW-wUyBGkB9mBVgKa-5ypeFzKg-b1CfWYjhjJtl0uuImGaJDpGRfC-sIdwj48DEjoAoZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8 HH_OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg2 8bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"},"name_long":"Garage Camera","web_url":"https://home.nest.com/cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","snapshot_url":"https://www.dropcam.com/api/wwn.get_snapshot/CjZieXljM0NwNjhiNTBVNVA4OFgtUzhFMnVIZHFHUG92X1Jld01ZdFZZdEEw UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"},"Pf9StMlw835uCff8nVNIk9VQ_6kfjW7LdBqtYAW0e2YP1bpklDD_rw ":{"name":"Living Room","software_version":"4620002","where_id":"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","device_id":"Pf9S tMlw835uCff8nVNIk9VQ_6kfjW7LdBqtYAW0e2YP1bpklDD_rw","structu re_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","is_online":true,"is_streaming":false,"is_audio_input_en abled":true,"last_is_online_change":"2018-12-02T14:30:00.000Z","is_video_history_enabled":true,"is_public _share_enabled":false,"last_event":{"has_sound":false,"has_m otion":false,"has_person":true,"start_time":"2018-12-01T18:33:01.981Z","end_time":"2018-12-01T18:33:13.947Z","urls_expire_time":"2018-12-11T18:33:01.981Z","web_url":"https://home.nest.com/cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/ielWkxOBdeNLXtA44Lzwvg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/cuepoints/ielWkxOBdeNLXtA44Lzwvg?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH _OpSd9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28b SDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","image_url":"https://www.dropcam.com/api/wwn.get_image/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu9ZPW0nq31btR3WALtg9C0_SJC9Bt9OmhAnUrfe8w14acb 0JLGsng51S4wuxnKRUI2s9U-vr_hcTZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd 9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","animated_image_url":"https://www.dropcam.com/api/wwn.get_animated_image/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw/Tz5Ms-8lvuRDiL46iBubu9ZPW0nq31btR3WALtg9C0_SJC9Bt9OmhAnUrfe8w14acb 0JLGsng51S4wuxnKRUI2s9U-vr_hcTZlwyvMcLFWs?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd 9umFNLqF7lnEbxHpAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"},"name_long":"Living Room Camera","web_url":"https://home.nest.com/cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","app_url":"nestmobile://cameras/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE","snapshot_url":"https://www.dropcam.com/api/wwn.get_snapshot/CjZQZjlTdE1sdzgzNXVDZmY4blZOSWs5VlFfNmtmalc3TGRCcXRZQVcwZTJZ UDFicGtsRERfcncSFktOQTh3cjN2dVNvUVAyeE53VGlPQkEaNmdUS0x5LUNI bFQzUFEwUEQ4TjJCTlZjYlp2c1RJbDd5UXdQZFEzc2lVWFMxVnBlRTU5ZDZk dw?auth=937fC5PHTrGPYrh_5LoqTG_7vB0tG8HH_OpSd9umFNLqF7lnEbxH pAVF2uonxssb3rk3tfueJqbW6KWTQxdXDfNtg28bSDv-2pj1n5w9x1SxIyHz-rEDlDY_EaaD25Lj5pchxrDSw9UcAgD-ssBX1jE_lUKWaE3NPLapDtbYV7xNboAdssc653ElIGaI_dbkPYm_hv2Eld2Z yE"}}},"structures":{"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ":{"smoke_co_alarms":["cw2LlF6qsbKCDgOS_DWaVw_VumSUMP-v","cw2LlF6qsbLqA03MjrNVDQ_VumSUMP-v","cw2LlF6qsbIC7tdKHdEmog_VumSUMP-v","cw2LlF6qsbKezVUlamBwZg_VumSUMP-v","cw2LlF6qsbI9-3Yz8mxZjw_VumSUMP-v","cw2LlF6qsbJ00jxLMM9T6g_VumSUMP-v"],"name":"Keeler","country_code":"US","time_zone":"America/New_York","away":"home","thermostats":["jhpfa2hTud6VFXqKex9wGg_VumSUMP-v","jhpfa2hTud79DcBweJ8uzg_VumSUMP-v","jhpfa2hTud7VcEDVwXnrBg_VumSUMP-v"],"structure_id":"R79YyrarqdwNec8ZQ2sghx2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","co_alarm_state":"ok","smoke_alarm_state":"ok","wheres": {"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3Xg3Pw":{" where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE01lWQ3 Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"cM3FFZRpi7J34 oeXHoRED9bD9v9jcrRz1q3NJIsGD4Ez5Q-l60Ae0g":{"where_id":"cM3FFZRpi7J34oeXHoRED9bD9v9jcrRz1q3NJI sGD4Ez5Q-l60Ae0g","name":"Bunk Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9 hA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE ZUqMqRwg9hA","name":"Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOE zrxhFivj_GTE2QFAGvJRsrA":{"where_id":"e4FzI0k3ounJK98jBApsiD 3MQnKhHOEzrxhFivj_GTE2QFAGvJRsrA","name":"Den"},"e4FzI0k3oun JK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g":{"where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","name" :"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqFCpQ xg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG SJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"Lpix1CTtYDaoIPWg3Bs4jRSB0j6WV1fJ_GptBKkClZkMGQclJ7wt-A":{"where_id":"Lpix1CTtYDaoIPWg3Bs4jRSB0j6WV1fJ_GptBKkClZkM GQclJ7wt-A","name":"game room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"SX5jf4lk0fhvhvICXFpN6ZmPJ2KW9CB2xJKL GbIgC5MSyIBY7nvpeg":{"where_id":"SX5jf4lk0fhvhvICXFpN6ZmPJ2K W9CB2xJKLGbIgC5MSyIBY7nvpeg","name":"Garage"},"EK_V79J_7it40 fCBhy3FDAAcBO-iJZxqRqyp9tdBOEvqjm4fxHNPPQ":{"where_id":"EK_V79J_7it40fCBhy 3FDAAcBO-iJZxqRqyp9tdBOEvqjm4fxHNPPQ","name":"guest bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFcdiDip AgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiJ6Lo6Sp _7HYWuw5bYHWbWz-Fibb-PMOIQ":{"where_id":"e4FzI0k3ounJK98jBApsiJ6Lo6Sp_7HYWuw5bYHW bWz-Fibb-PMOIQ","name":"Library"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTHmMVMfIExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":" Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"},"rpEPAZvX7Uedr-fUP4ISLb6ps-2HvZ_6tl2bTfJyvWVyMpw_0ZOykg":{"where_id":"rpEPAZvX7Uedr-fUP4ISLb6ps-2HvZ_6tl2bTfJyvWVyMpw_0ZOykg","name":"Workout Room"}},"cameras":["Pf9StMlw835uCff8nVNIk9VQ_6kfjW7LdBqtYAW0e2YP1bpklDD_rw","by yc3Cp68b50U5P88X-S8E2uHdqGPov_RewMYtVYtA0P1bpklDD_rw"]},"-enKqJC63ZecTFKuCR8Mrh2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ":{"smoke_co_alarms":["cw2LlF6qsbI2W2OjoNaK5g_VumSUMP-v"],"name":"Apartment","country_code":"US","time_zone":"Amer ica/New_York","away":"away","structure_id":"-enKqJC63ZecTFKuCR8Mrh2GGHWXBjDY-jcgqsgE7WTIthwA7Tm-EQ","co_alarm_state":"ok","smoke_alarm_state":"ok","wheres": {"H5yDjsMy1mOkv-CjsBlTWuH1z8GtPvJlJ-MuMSGXKDjnBdrolvZDKQ":{"where_id":"H5yDjsMy1mOkv-CjsBlTWuH1z8GtPvJlJ-MuMSGXKDjnBdrolvZDKQ","name":"apartment"},"dPBlunSHE0voHzocQ DzP85nMasM73FnTHFktGtgBBpx5NT-z-A6AoA":{"where_id":"dPBlunSHE0voHzocQDzP85nMasM73FnTHFktGtgB Bpx5NT-z-A6AoA","name":""},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TE01lWQ3Xg3Pw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEz rxhFivj_GTE01lWQ3Xg3Pw","name":"Attic"},"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ":{"where_id":"e4FzI0k3ou nJK98jBApsiD3MQnKhHOEzrxhFivj_GTHd6V_0CxFjuQ","name":"Back Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEQbYDGG26I UQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE QbYDGG26IUQ","name":"Backyard"},"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4FzI0k3ounJK98jBA psiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name":"Basement"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEYA":{"wher e_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEtu3v5WLcEY A","name":"Bathroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFi vj_GTHDWahECEab0A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTHDWahECEab0A","name":"Bedroom"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9hA":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEZUqMqRwg9hA","name":" Deck"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE2QFAGvJRs rA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 2QFAGvJRsrA","name":"Den"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEz rxhFivj_GTFsTZUOmdSi_g":{"where_id":"e4FzI0k3ounJK98jBApsiD3 MQnKhHOEzrxhFivj_GTFsTZUOmdSi_g","name":"Dining Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG9A7cHHQwb jw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG 9A7cHHQwbjw","name":"Downstairs"},"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHqQGf0TJGeMA":{"where_id":"e4FzI0k3ounJK98j BApsiD3MQnKhHOEzrxhFivj_GTHqQGf0TJGeMA","name":"Driveway"}," e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nvpeg":{"wh ere_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTESyIBY7nv peg","name":"Entryway"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxh Fivj_GTGEY2KDrCGVSQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTGEY2KDrCGVSQ","name":"Family Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGSJkjqFCpQ xg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG SJkjqFCpQxg","name":"Front Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEB5E9EV7d9 3w":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE B5E9EV7d93w","name":"Front Yard"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFwQPsds-gMMg":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_G TFwQPsds-gMMg","name":"Garage"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTFcdiDipAgTDA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTFcdiDipAgTDA","name":"Guest House"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGh8lvkqT2 xlQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GT Gh8lvkqT2xlQ","name":"Guest Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE3y9MRdwpi cA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE 3y9MRdwpicA","name":"Hallway"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTFAbyKtgqyTVQ":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTFAbyKtgqyTVQ","name":"Kids Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAii Ow":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG goDbPcAiiOw","name":"Kitchen"},"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGqA1DwGeRj6A":{"where_id":"e4FzI0k3ounJK98jBAp siD3MQnKhHOEzrxhFivj_GTGqA1DwGeRj6A","name":"Living Room"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGp8x7lb5eA ZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTG p8x7lb5eAZA","name":"Master Bedroom"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHBlgeGD kyHZA":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_ GTHBlgeGDkyHZA","name":"Office"},"e4FzI0k3ounJK98jBApsiD3MQn KhHOEzrxhFivj_GTFmAHn8c7YyOQ":{"where_id":"e4FzI0k3ounJK98jB ApsiD3MQnKhHOEzrxhFivj_GTFmAHn8c7YyOQ","name":"Outside"},"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTF7TF-AvlFYWQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFiv j_GTF7TF-AvlFYWQ","name":"Patio"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrx hFivj_GTHmMVMfIExGOw":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQ nKhHOEzrxhFivj_GTHmMVMfIExGOw","name":"Shed"},"e4FzI0k3ounJK 98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg":{"where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGFfwxFGjK0Wg","name":" Side Door"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTEmTjvca91Q 9A":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTE mTjvca91Q9A","name":"Upstairs"}}}},"metadata":{"access_token ":"c.0Oxljhp5lgCsUHWfaDVBpDjL9QctH67YaAIYZ5ywI816H86rPZpfGbX osxU52znUBMhjdGIpGPAyGJopsaszcyolfDm1tqhiAPU2LSiTtGgrzi0vTXT ALsrWDEcSLl3Y3DI5CVAib0WhmhgE","client_version":5,"user_id": "z.1.1.BcfxmNPzUEd5BlmDeVhgYNAF474OIKe95zlgEpBe6jE="}}}
    Somehow your system is using an old NestSharp.dll.
    Reinstall the plugin from the updater, and make sure there isn't a NestSharp.dll in your Homeseer app folder, this dll should only be in bin/Nest
      Deleted the plugin and reinstalled. For good measure, restarted the system between every step. Now I see everything. Perfect fix, thanks!
