Nest Alexa Integration
  • Nest Alexa Integration
    Anyone else having issues with Alexa reporting back the humidity instead of the actual temperature? I have the Alexa Homeseer Skill and when I ask what the Temperature is in the room, she give me the humidity number in degrees (45 degrees), which isn't correct. So not only is it wrong but it doesn't even report back in the correct units for humidity. If I check the status of the Nest, the numbers are all reporting back correctly on the Homeseer webpage. Is this an issue with the plugin or Alexa Skill? My guess is the skill but just wanted to see if anyone's is having the same problem.
