Linking device to Nest desired temperature only works with integer values ?
  • Linking device to Nest desired temperature only works with integer values ?
    I have a virtual switch with 'desired temperatures'. I have linked this to the corresponding Nest device. If I change the virtual switch to 19 degres, The Nest desired temperature changes to 19. It works with 20, 21,22 all fine. But when I select 19.5 or 20.5 or 21.5, nothing happens. The temperature on the Nest device does not change. I am not sure why only integer number work. I have also linked the Nest desired temperature device to my virtual switch. If I use the + - buttons to change the temperature on teh Nest device to 20.5 degrees, the virtual switch does change to 20.5, so it works in that direction, but not from virtual switch to Nest ?
