Spud,
Thought I’d ask the question, since I already have the plugin and have been using it for some time. I complained to google about the WWN situation, but how much of the plugin is still going to work? (If you know of course).
I know that the IFTTT connections will still work if made before the end of August. So my question is, do I need to make them now or continue using this plugin? I could probably do some of this with IFTTT but I don’t know for sure, and your plugin is preferred.
My main use of the nest plugin is :
Using the temperature device from the nest thermostat to run my heating.
Forcing the home and away into Nest from Homeseer as I don’t like waiting DAYS for nest to update if at all 🙄
Using the camera on the drive as a motion sensor for the outside lights and taking snapshots for security.
Changing the heat/eco/off device and the target temperature from homeseer when approaching home so it comes on if cold. (Can’t believe the nest doesn’t do this anyway)
I also have notifications when the nest devices change so I can keep an eye on it.
All in all it’s a crying shame, but a heads up on what I need to prepare for will help.
Thanks in advance.
Cheers
J
Thanks in advance.
Cheers
J
