Any idea when the Nest plug-in work again with the google change? Would love to know if I have to get rid of all my thermostats?
Nest plugin still going to work after August then?
Originally posted by smithdavee View PostAny idea when the Nest plug-in work again with the google change? Would love to know if I have to get rid of all my thermostats?
Nest thermostats can only be integrated with Google Assistant from now on.
https://nest.com/ca/whats-happening/...l-nest-devices
- Likes 1
Already converted accounts are totally screwed as per:
Unless you buy a Google Assistant compatible hub and have HomeSeer control it.
Business 101: take a monopoly position, and then abuse it. I'm sure eventually the EU will step in, but as it stands there are too many competitors doing the same thing (Apple, Amazon, and Samsung) so then it is simply fair marketplace practice. Personally I don't want to end up with 12 different hubs to get everything to talk to each other, so I'm sticking to companies who have no vetted interest in forcing you into their 'ecosphere'.
Of course that was my initial thought behind buying a Nest thermostat as well, and then one month later Google bought the company.
At least they retain their value in comparison to what a replacement would cost, and are therefore easy to resell if needed.
Blink cameras are another example.
Crowd funded, promises of API etc. Started to deliver on the promise, Amazon bought them. Lockdown.
They left the anemic IFTTT controls in place and nothing else.
I think this worse because of the crowd funding origins.
Totally understand that the Blink founders made a fortune. However maybe the crowd funding sites should make companies sign a credo stating that they will deliver on their promises in the event that a big company buys them before they start raising money?
Originally posted by KenBeanNet View PostIs it possible to get a key for the plugin though? I never bought it as I didnt have time to setup Homeseer. And now I cannot buy it.
thanks
I just read that the works with Google Assistant API is released in begin 2020 for developers. For personal use not until late 2020. So it will take some time before a new plugin is possible
https://blog.google/products/google-...ith-nest?hl=nl
https://developers.google.com/nest/device-access
Google did come out with a $5 Nest device access setup @ https://developers.google.com/nest/d...s/registration
No idea if that will make things work as-is, or if more is needed.
The new Google Nest Device access API is a replacement for the deprecated Nest API, but is more limited, for example Nest Protects are not supported (yet?).
My old HS3 Nest plugin won't work with this new API
A new HomeSeer HS4 Google Nest plugin that target this new API will be probably created, but no timeframe yet.
- Likes 1
I am using the old HS3 Nest plugin and like it mainly because it allows instant feedback when somebody makes a manual change to a thermostat. I have never been able to use Ecobee or other alternative brands because their feedback from manual changes is much too slow to support my requirements. Do we know if the new Google Nest Device API will have the same rapid response as the old API or is it going to be dumbed down?
