Heat/Cool adjustments not working
  • Heat/Cool adjustments not working
    Spud, I've been using your plugin to create effect, thx. Today I ran into an issue. I placed my stats in Heat/Cool mode and found that adjusting the temp via the high and low settings is not working. I tried both from the device page and from an event. Updating the temp on the stat directly IS still reflected on the device page, so communications is happening.
    If I switch back to Cool mode, the function works normally again.
    I'm on v3.0.0.34 and i'm not seeing any errors in the logs.
    Any ideas?
    (thx in advance)!
    Bill
    Current Date/Time: 10/28/2019 1:42:37 AM
    HomeSeer Version: HS3 Standard Edition 3.0.0.534
    Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 1 Day 17 Hours 32 Minutes 20 Seconds
    IP Address: 127.0.0.1
    Number of Devices: 298
    Number of Events: 92
    Available Threads: 199
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    2.0.11.0: BLEditor
    3.0.28.0: BLLock
    1.0.1.0: BLTEDPro
    1.3.7.3: Device History
    3.0.0.34: Nest
    19.6.3.1: TPLinkSmartHome
    3.0.1.252: Z-Wave
    Set the log level to Debug from the config page, and post what you get when you try to change the setpoint.
