Miss the plugin so much. I was playing around with Homebridge and found out that you can get a new token from a Google account instead of a Nest Account. Is there any possible way to use this into the Homeseer plugin. https://www.npmjs.com/package/homebridge-google-nest
Nest Thermostat on Homebridge
spud - is the above possible with regards to your plugin being updated using the google account instead of the nest account which lexusplexus is suggesting?
I read somewhere in the HS forum a suggestion to use a google mini to send commands via audio to another gogle device. It just so happended that google sent me a free mini, so I sat it next to a goole assistant hub and turned the Microphone off on the mini. I now use the chromecast plugin to control the nest thermostat via homeseer. Its a liitle bit messy and circuitous but it works well. I am using it with HS Buddy geofence to control the temp in my house when I am leaving or entering the geofence.
