Nest and kinect
  • Nest and kinect
    I am working on a completely VR controlled system and was wondering if it is possible to control nest with VR from the kniect plugin
    for example issue a command <set temperature to X degrees> and have the nest respond
    Looking for some help on how to do this if it can be done
    Cheers Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
    you could do something similar to the script in this post: http://board.homeseer.com/showpost.p...27&postcount=3
    but you know what, this request of being able to control a device using kinect voice recognition comes so often that I think I'm going to try to make it super user friendly. Something like the native hs VR, i.e. you would just have to check a checkbox in the device config, and then you would be able to use commands like: "set device_name to device_status" without creating any event.
    How does that sound?
      That would be awesome, I'm in the middle of adding a ton of vr events, just ticking a box would be so much faster. I plan to add 10-20 kinects, to get total house occupancy status and vr control to every room. Btw my local gamestop has used kinects with ac adapter for 29.99. Website shows 39.99.
        That would be awesome if it had the similar functions to the hs native vr. As long as it dosent sacrifice accuracy and reliability. While looking at advancing the vr is it possible to add the ability to build delayed events like hs vr does. For example turn on the outside lights at 800 pm for 2 hours.
        What do you think?
          I second that can't wait to see this next version!
            have a look at http://board.homeseer.com/showthread...30#post1132030 for voice control of devices without using events or scripts.
